Ford mileage correction for new cluster
Hi guys,
Fitted new instrument cluster to my ford (UK/EU fiesta 2006) managed to reprogram the immobiliser and match the cluster to the car using forscan, but the (digital) milage is incorrect. Anyone know a cheap (or free) way to fix this? The new odometer reading is about 30k lower than it should be. I can get it reprogrammed for about £50, but not going to spend that just to sooth my OCD. I'm thinking copying the eprom data from the old cluster and writing it to the new one might be an option, but no idea how to do that? Supposedly the icu and other modules hold a running total of the milage anyway to prevent "clocking" so can't be too hard to get that to show on the dash surely? Tried resetting the modules, but nothing changed. You guys are the brains here, any such software (freeware?) that you know of? Nedlom |
Not sure how the laws are in your area but in the US changing the odometer reading is a federal offense even if you're just correcting a replacement to match the original. The penalty for odometer tampering in the US is $10,000. per incident. I once had to replace an odometer on a pickup I had. It was still under warranty when it was replaced so everything was documented by the dealer and I also made notes of the change but the new odometer had a 000000.0 reading when it was installed. If you do find a way to make the change and the laws are similar to the US I suggest not making it public.
You could input a signal to the speed sensor at say 120 mph and let the mileage accumulate, but you would have to leave the ignition on non-stop for 10 days straight. Suppose you could remove the cluster and do it on the bench as well.
Sorry guys, been snowed under in work...
*funny story - years ago I used to work with a guy (thick as bricks) who was selling a high milage, but otherwise spot on BMW. Thought £50 spent "correcting" 😉 the milage would be a good idea. Worked well until he proudly pulled out the "full dealer service history" which showed it had already had the next 50k worth of servicing done. Plus the proposed buyer was a local thug who didn't take too kindly to our man trying to con him. Play stupid games, win stupid prizes... |
Copyright ©2000 - 2022, vBulletin Solutions Inc.
