Ford wants to Replace Sparkplugs with "Lasers"
This reminds me of one of the best scenes from Austin Powers:
My question is how will they keep the lenses clean? Lasers. That's one tall ladder. Ford wants to Replace Sparkplugs with Lasers : Gas 2.0 |
Assuming that it may actually work.
Detonation & pre-ignition are caused by an increase in pressure causing a temp. spike in the combustion mixture. Older engines with a single spark plug located on one side of the cylinder is more suseptible to this than an engine with a centrally located spark plug. Large engines (old airplane engines) benefit from having multiple spark plugs to help even out flame front propigation. This allows the compression ratio to be increased, thereby increasing engine efficiency. If they split the laser beam like they are talking about, they could effectively have say 5 or 6 "spark plugs". This should allow for an increase in compression ratio without experiencing pre-ignition. If the laser works & uses no more power than spark plugs, I'd believe you could get an efficiency increase. Don |
I agree that there would be an efficiency increase if it worked. I think it would work in the lab. The question is how much will it cost and how reliable would it be considering the dirty place the combustion chamber is?
In an alcohol powered machine, this would probably work better because it's presumably cleaner. A laser needs a clean lens to produce a good beam. How would you keep the lens clean? |
Hello -
I am cross-posting related threads : http://ecomodder.com/forum/showthrea...tion-9335.html CarloSW2 |
Re:keeping the lens clean - It kind of looks like the focal point of the beam might work in your favor. Using a stratified charge, the focal point (ie spark) may be in the fuel-rich zone near the piston head. In that case, the lens might be in an extremely lean zone. Besides, since the engine was already running leaner than standard, carbon deposits shouldn't form. If you look at pictures of conventional plugs running in a too-lean environment, the plug will be very clean. Melted tip, sure, but clean. Other deposits tend to be symptoms of other problems (oil leak or contaminated gas).
It's funny they laughed at the laser plugs when they first saw them and said no. You guys must be doing a good job for them to reconsider new ideas and possibly better technology. Imagine that there could be a difference in spark plugs that's why I use halo plugs they work better. We can improve on almost everything. Remember Ross Perot when he said you don't have to invent the light bulb just make it better. :thumbup:
Sounds like a gimmick. Remember that the spark plugs purpose is an accurate ignition point just before TDC. They've tried everything from multiple spark plugs (good idea) to microwaves. Modern engine computers calculate plug degradation and other engine variables to assure even combustion timing.
Does anybody remember a few years ago when VW came out with their gasoline fed diesel cycle engine? Though it was a true diesel cycle using gasoline instead with something like 14 or 18:1 compression, they added an igniter (like in an oil furnace, not a spark plug) to assure accurate timing burn of the fuel. No throttle butterfly and timing via direct injection. The prototype engine was said to produce around a hundred horsepower and get over 80 MPG in a field tested Golf. Lots of hype in magazines, then nothing. It apparently worked but who knows it could have been a not passing emissions sort of deal. :cool: |
It wouldn't pass emissions.. NOx would be way off the charts for a gasoline engine, because of the incessantly lean nature of throttle-less engines.
Who said no? :confused: Who here encouraged them? :confused: Do Halo plugs work? :confused: Didn't you used to hawk Pulsestars? :confused: Have you ever improved on anything? :confused: I like Ross. :thumbup: |
Re: halo plugs. No noted difference.
Lasers are all cool and stuff but...
What we really need is better batteries, not more expensive gasoline technology. I personally think they are throwing money at a dying technology. I would concentrate on spending the money on battery research. Electric motors are by far the most efficient practical solution for vehicles. The biggest gains from improving the gasoline engine have been made already. Gasoline engine efficiency up to 25% for otto or 35% for Atkinson. (If you drive it sensibly) Electric motor up to 95% efficient and the energy can come from almost any source. As we all know here, Aero improvements and taking loads off the engine give the biggest MPG gains. That's the low hanging fruit the automakers should be taking advantage of. I realize that the combustion engine is here to stay in some applications but right now we should be getting off the gas ASAP And don't even get me started on Hydrogen |
Personally, I think money should be spent in getting us away from gas, but not away from combustion. I truly think that biodiesel, especially from engineered algae, has a great potential. From an energy density standpoint, liquid fuels are just plain hard to beat with a battery for the foreseeable future. For that one reason, I continue to like the idea of a well designed series diesel hybrid. Even relatively small capacity battery systems can do a tremendous amount to smooth out variation in power demand, meaning you can optimize engine size and rpm for efficiency.
I think people should ride more bicycles and Songis.
Frank,
Where did you get that fantastic quote? I must know. |
How did you miss this?!?
http://ecomodder.com/forum/showthrea...tml#post118044 It's too awesome for words. I think I have found my new spiritual leader. |
I am bringing in the overture, for aft of the mast is bonkers. Is the finding of fruit longer than the given woo? I know knot.
Awesome! Thanks Frank, you made my day. At the plastics shop today, I overheard a great one-versation about magnets and free energy and inventors getting visits from dark figures in black limousines. There were even sketches of levitation machines. The most salient point from this sage to his hapless nodder? "Everything we have been told is a lie to keep us ignorant." Now I can sleep. |
I envy you. These things keep me awake until dawn. Every night.
