Fried my Guino
I was sitting at the gas station refilling my tank this morning and I went to remove my Guino from the dashboard to get it's current tank data so I can compare it to the pump and odo.
This probably wouldn't have been an issue if I had just put the buttons, or access to thereof, on the outside of the enclosure. Since I didn't I have to remove it from it's velcro'd location in front of the tachometer, open the front of the box, and hit the buttons from there. Usually it's fine except for the odd power cycle due to nudging the cable here and there. When I touched the box, I got a static shock that actually registered on the display (the instant MPG went to 9999 from 0000 so I'm guessing it thought it was a VSS pulse). I was a bit nervous after that, but since it returned to normal I figured it was ok. Now when I grabbed the box to pull it off the case closed suddenly, as if it wasn't closed completely to begin with, with a snap that put the display in an odd position (all the way through the hole, when it's normally angled slightly) and messed up the screen quite a bit. The left half was ok but the right half faded from barely visible to not visible. I was a little freaked out, but hit the buttons to make sure it wasn't completely gone. The screens changed and it reset the current and tank but then I saw smoke coming from between the boards, the screen went blank, and I smelled burning electronics. I removed the phone cable after that and hopefully I just fried the screen. Not good. I'll have to dismantle it at home tonight to see if I can find where it burnt and for now I have no instant feedback. Maybe I can fix it, maybe I'll end up holding out for the OBDuino. *sigh* That'll teach me to not finish my projects before using them. :mad: |
My sympathies! Hope you get back to instant feedback soon.
Static is a common phenomenon in cars, and I wonder how it would be possible to reasonably shield / harden the MPGuino against such instances. Maybe it needs some collaboration and chasing. I am also worried about the raw 12V from the battery - There is nothing for surge protection on the MPGuino, whereas I routinely come across specialized surge resistant linear/switch mode regulators being advertized for automotive use. At least some sort of surge protection diodes should be used on all inputs and power lines. Any comments? |
I've scoped the 5v output while playing with various inductive loads, the large and small caps and the 7805 seem to do a good job.
Yup, I fried the screen. One of the big black dots on the back was burnt. Of course the solder sucker and desoldering braid did absolutely nothing helpful to remove the solder so now I need a new bridge piece to go along with the new screen. The main board is a bit chewed up as well so hopefully I didn't ruin it.... I'll have to test it...
Anyone have part numbers for ordering the screen and bridge outside of the kit? |
This type of situation brings up the question of circuit protection. Considering how easy it can be to fry the MPGuino, how easy would it be to damage the cars control system at the same time?
What I want to know is if there is a way to add circuit protection to the unit? Possibly optoisolators and fuses. Has anyone else tried this? Would the optoisolaters cause problems with signal delay or loss? I have looked at these units for a while but this is a situation that I have always worried about. I would personally isolate both the data lines and would install a fast acting fuse on the power line. Anyone else tried this? Could the car get damaged by sending 5v or grounding any of the lines? |
I don't know that "easy to fry" is a fair generalization. In a home built unit, stuff happens, yes, but adding more stuff generally reduces the chances of success. It sounds like a layer of plastic between his board and LCD would have helped here.
The preassembled ones currently come with a layer of plastic between the LCD and the circuit board. They also do not have a bootloader and other changes and have not yet shown the flash flakiness seen in a stock arduino configuration. The data leads have 50kohms in series so it's hard to fry much of anything with that in the way. And a large cap with reverse polarity protection on the power leads make a reasonable supply circuit. |
An opto-isolator would probably introduce more interference on the signal lines. You have to supply enough current to light an LED with an opto-isolator, as compared to triggering a high impedance input pin.
As for the other general "stuff happens" concern, I don't know that one can prevent the occasional miswiring in a cost effective manner. Even "professional electronics installers" occasionally miswire something or short something out. But if the thought of hooking up 4 wires causes you unusual distress then you should look into an obd based solution. What kind of car do you drive? P.S. Welcome to Ecomodder :) |
Dont get me wrong here, I love working on wiring which is why I am becoming an electrical engineer. I just like to think about the ill-effects a project could cause before I do work...sometimes...at least when it comes to something as expensive as a car. Personally, I believe all cars should have some sort connection for modders to safely tap into the cars systems but unfortunately its not that easy. As for my car, I drive both a 2002 Chevy Z71 Suburban and a 1987 300TD Mercedes. Both cars are unique for the work ive done on them. The Suburban could be considered the electrically modded car. I have done the basics such as replacing the entire radio system with a much higher quality system capable of dual zone sound, I have installed flood lights under the rear for backing up in the dark, and I ran a 100 amp electrical connection from the battery to a fuse block under the cup holder for my inverter and for future projects. I have even pulled apart most of the dash board electrical system just to see how it worked. While this car is not the most fuel efficient car out there, we only really use it when we need to haul large loads or go on road trips. The other car, the Mercedes, is my main focus of installing a MPGuino. The background of this car is interesting. First off, its been converted to run on Bio-Diesel, Vegetable Oil, or whatever else we want to put in it. The reason for this is that my Dad runs a bio-fuel research program at my old high school on the weekends. We are researching different fuel blends and their emissions. Currently, we have been using a set test route to measure our distance and we have been getting our MPG by weighing a test tank we have in the trunk. While this method is great for overall MPG, its not practical for instantaneous MPG. I have the wiring diagrams for the car as well but I did hear a mention that Diesel cars have a slightly separate signaling method which worries me. Anyway, I should probably start a separate thread if I want help on that, I really dont want to derail this topic any more than it is. |
For your mercedes, I would suggest taking a look at some of the mpguino diesel threads, you will be in for some pretty serious experimentation at least:
http://ecomodder.com/forum/showthrea...tion-6778.html Or the "carbureted mpg monitor" thread might give you some ideas as well. http://ecomodder.com/forum/showthrea...gine-1123.html |
*UPDATE*
Ok, so 3 months later I have a replacement LCD (went with the blue), headers (got 4 sets of extras), and new tactile buttons (much taller). I'm probably going to redo my enclosure (new screen is slightly larger) and actually make the buttons accessible without opening it this time (duh). What I'd like to do is move the buttons to the top of the enclosure (standard Rat Shack project box). Anybody else do this with the original kit? Any advice on how to mount the buttons on/through the top of the project box? |
Finally got the screen installed last night (what a pain in the @$$) and low and behold, my calibration data was still in there! Huzzah!
http://spidermouse.us/images/smilies/yellow/dance.gif I've got an idea for remoting the buttons to the top of my enclosure, but I'll need to wait until I pick up some more wire and a small breadboard. *edit* And here's a pic of it back in it's rightful place :) http://spidermouse.us/modding/Car/Corolla/SSPX0252.jpg |
On the first MPGuino I made, I had wires running out for the switches, and I had the switches superglued to a piece of plastic. They held great, the rest of the board was a mess though, and I ended up getting a kit version to keep it clean, so I didn't need the switches.
I would just drill small holes in the top (enough for the button part to stick through), and glue the square part to the top of the box. Superglue, or hot glue should work fine for it. Then, just connect the wires from the switch to wherever they went on the MPGuino. |
That's the idea I was going for; I got extra tall buttons just for that reason. I'm hoping to be able to screw a breadboard in place instead of glue just so the unit is easily removable from the enclosure. The tough part will be getting the wires to the kit; I have the original kit version that has the USB port on the flip side of the board from the buttons.
