Old 12-11-2021, 04:08 PM   #1 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Hypermiling again!
Hypermiling again! I’ve restarted commuting after working (very little) from home since March 2020. The display for last night’s trip home shows 60 miles at right around 65 mpg. Full disclosure: With snow tires mounted, the tire outer diameter is slightly reduced, so the corrected readout would be 63.92 mpg over 58.7 miles.
2000 Insight, tires at 46 psi, radiator block, and a lot of pulse and glide.
I have some history in this little club. Here's a link to Outasight's mpg history here on Ecomodder - and you can see the links there, to the other car's I've hypermiled before this one.
https://ecomodder.com/forum/em-fuel-...vehicleid=9520
Coast long and prosper.
The Following 4 Users Say Thank You to brucepick For This Useful Post:
alexshock (12-12-2021), freebeard (12-11-2021), Gasoline Fumes (12-12-2021), MeteorGray (12-13-2021)
Old 12-11-2021, 04:53 PM   #2 (permalink)
EcoModding Lurcher
mort's Avatar
Yay!
The Following User Says Thank You to mort For This Useful Post:
brucepick (12-11-2021)
