front scoops on aventador and others
ok so u know those big black air scoops on the front of the aventador, what are they for?
the engine including radiators are in the back so could they possibly be scooping air for? if they arent scooping air then what are they doing? http://www.wheelsandmore.de/de/Tunin..._Aventador.jpg this is a link to an aventador from google images i can understand the side scoops behind the doors channeling air in to the engine bay but what possible use could there be for scooping it at the front?!?:confused: thanks |
Looks, aesthetics, aggressive stance, etc.
Brake cooling.
Brake cooling?
Timing is everything! LOL
So the driver and passenger can stretch their legs out?
Flintstones braking ducts.
Lamborghini Aventador: the design - Car Body Design
"In the front end we find a trademark design element: the double air openings which provide cool air to the brakes. The other cold air intake is connected to the power steering radiator." |
front ducts
The new Hurac'a'n does the same thing.
It is an all wheel drive,so some of the air may be for front differential cooling as well. http://i1271.photobucket.com/albums/...ntitled410.jpg The new Corvette uses a single inlet duct,then directs the air internally with ducting for the forebody bits. At Cd 0.29 vs Cd 0.36 for the Lambo.,it's a lot better engineering.(maybe not quite as sexy) |
Whatever they may actually be doing there, that's prime real estate for managing airflow in the front wheel-wells, one of the most problematic areas on a car.
i spoke to a fellow today who said they scoop the air at the front and channel it up to outlits up at the windscreen, this creates downforce at the front and helps to push the air over the car when it hits the windscreen.
seems kind of counter intuitive for a car to go fast, but he said the lambo is designed for downforce rather than top speed like the veyron which also sounds legit. the brakes must get pretty damn hot then :o |
It might also have something to do with downforce, but I'm not sure if it would be worth to channel the air up to the windscreen.
downforce/top speed
Here,the Countach shows it's dirty but stable form. http://i1271.photobucket.com/albums/...titled5_10.jpg You really pay for the draggy wings http://i1271.photobucket.com/albums/...d2/06-2823.jpg The Aventador loses the rear wing of the Countach for a 40 count drag reduction,but they're all over the road on track. http://i1271.photobucket.com/albums/...Untitled22.jpg The Veyron ' begins' a bit cleaner than the Lamborghini http://i1271.photobucket.com/albums/...ntitled3_2.jpg As velocity builds ir becomes dirtier to maintain stabilty http://i1271.photobucket.com/albums/...ntitled2_2.jpg At 268 mph,Volkswagen doesn't want their rich clients dead in their car,so the Veyron gets really dirty http://i1271.photobucket.com/albums/...ntitled9_2.jpg The flow ends up pretty hideous,but at least the driver lives to see another day http://i1271.photobucket.com/albums/...ad2/scan32.jpg :) |
The converging duct means the air out of the vents is moving faster and pulls any high pressure at the base of the windshield sideways. As opposed to using the air for an air curtain over the wheelwell opening. The flow for brake cooling is just a plus. |
Aventador nose
The July,2013 MOTOR TREND had a small article about the Lambo on pg. 18.
They said the 'new nose and tail' improved aerodynamic efficiency by 50%,high-speed stability,and engine cooling. |
