Front skirts in production
Found out there are some beautiful aerodynamic buses in production with front wheel skirts. Turning photos reveal a lot.
http://i148.photobucket.com/albums/s...b/IMG_2613.jpg http://www.ssfoto.net/images/lvb44.jpg http://www.ssfoto.net/images/lvb64.jpg http://www.ssfoto.net/images/lvb55.jpg http://www.rapidtransit-press.com/apta-nabi01.jpg http://i54.photobucket.com/albums/g1...s/IMG_7675.jpg http://i54.photobucket.com/albums/g1...s/IMG_8431.jpg |
1 Attachment(s)
Great find! Last picture seems to indicate that the front wheel skirts are mounted to the non-rotating portion of the wheel hub... would be interesting to get some detailed information about the mounting mechanism.
Seems like that could be mimicked on a car using a mounting system similar to the Lotus / Locost 7 front fenders, like so: http://ecomodder.com/forum/attachmen...1&d=1278997732 Unlike the Lotus 7 fender, it wouldnt be necessary to provide coverage over the top of the tire, only along the face of the wheel... so it could be made for "relatively" easy removal for access to the wheel & tire itself. :thumbup: |
XJguy -
Pretty cool. In the LA Metro case, I have read that the secondary (or first-ee-air-ee?!?!) purpose is to protect people from getting caught in the wheels. CarloSW2 |
NachtRitter -
CarloSW2 |
Those buses look simply awesome, not just the wheel cover part..The second picture especially reminds me a lot of trams (streetcars) I guess they figured out aerodynamics does make a difference, even in slower moving buses
http://jfi.uchicago.edu/~rschroll/france/00126.jpg |
I realize one issue with my suggestion is that you'd have to account for suspension travel within the wheel well... Might be able to mitigate that by limiting the "height" of the cover (so it doesn't extend much beyond the top of the wheel) and maximizing the "width" (front to back of wheel well). I would draw it, but my drawing skills are worse than a 2 year old's :p . Anyway, then the gap from top of wheel well to wheel cover could be closed using a short flexible skirt ("mini-skirt"). This is just arm-chair designing, of course... no idea if it would actually work in real life. Maybe a basjoos style front wheel skirt would be significantly easier to implement... |
Thanks that is a solution for the front wheel that i had not thought about and the Lotus 7 pic helps for another way to mount it. I really need to make some wheel skirts.
1984 probe iv
4-season performance might limit these to areas outside the snow-belt.Don't know. P.S. The French 'Dauphin',circa 1934 had virtually an identical setup.Back to the future! |
The issue with having the skirt attached to the kingpin is that it adds to the sprung weight. (This probably doesn't matter much on a bus!) I'm hoping to attach it to the inner fender and only connect the steering tie rod move the skirt.
It is interesting that it would seem to worth doing this on a local metro bus. |
Neil -
Seems like it does make more sense to mount the skirt "support structure" to the body of the car rather than to the wheel itself. Might be able to use the top of the shock tower and the control arm mounts as the three attachment points for the swivel at the top? I think the issue there is that swivel piece would need to be relatively beefy to hold up over time. On the other hand, the heaviest part of the support structure would be the frame... that wouldn't be more than a pound or two, would it? The skirt material itself can be relatively light. So even if it were mounted on the wheel, it isn't much unsprung weight. It probably comes down to the ease of construction and maintenance vs the ideal. |
I would love to do something like this but how would you change a flat tire?
You would have to undo the fasteners on the skirt, to get access to the wheel and lug nuts?
what happens if that bus hits a bump while turning i dont see much of a gap between the skirt and the top of the fender.
http://www.webkits.com.br/news/artic...3-Delahaye.jpg |
A reference from a reproduction house indicates that Quote:
Neil -
2 Attachment(s)
OK, found a few better pix...
First, I realized that the picture of the white NABI BRT bus shows it after it has settled down on it's air suspension, so the gap on the front wheel skirt is less than it would be while driving... a bit deceptive: http://www.rapidtransit-press.com/apta-nabi01.jpg The actual gap when the suspension is at driving height is a bit more noticeable: http://ecomodder.com/forum/attachmen...1&d=1279177327 Second, a good side shot of the Las Vegas bus (the StreetCar RTV by the Wright Group) shows very well what I meant when I said: Quote:
Now that I look at the original pics of the StreetCar posted by XJGuy, I notice the gap on the top of the front skirts a lot more. |
NachtRitter -
1 Attachment(s)
Re verticle hinge: if the wheels turn left then the rear opens on the right side and the front on the left, am I correct? Something like the suicide doors in the Panhard Dyna Z? http://ecomodder.com/forum/attachmen...1&d=1279178642 Could this cause a parachute effect on one side when turning above a certain speed? |
Nevyn -
CarloSW2 |
Do these around-the-tire skirts reduce drag by A: partly blocking the wheel-well opening or B: reducing the drag of the wheel/tire or C: both?
Piwoslaw...
Carlos... Quote:
David... Quote:
Looks like the front skirts may be mounted directly to an axle sleeve that extends through the center of the wheel. The skirts look too large and heavy to be attached from the inside only to me.
@ bike4miles - perhaps you are right, but it could just be that they're fibreglass and they're professionally made, thus I assume actually quite light. If you just attach that skirt at the front, back and top, it should be quite sturdy, especially if in plan your front, back and top mounts form a triangle shape too where connected on the suspension.
This should be more than sturdy enough for a lightweight fibreglass / plastic part. |
function
Porsche's 60K10 was like this,and the 356 Panamerican racer.Nash Aeroflyte also I think.Metropolitan? Sounds like we need to dedicate a thread to skirts,past and present. |
This got me wondering why a fully-enclosed front fender like the Delahaye wouldn't be a a reasonable proposition for an ecomod. Properly shaped, the small increase in frontal area would (should?) be more than offset by the large reduction in drag. Overall vehicle width shouldn't be an issue - if the full-size dually pickups fit in a lane, so should bulbous front fenders. It would also eliminate all those complex mounting and articulation problems.
Negative-offset front wheels would help, as long as one doesn't try to emulate Messrs. Vettel and Button. |
curb-finders
Simple curb-finders might help as a 'reminder.' |
1934 Dubonnet Dolphin
Let's try this:
http://m.blog.hu/au/autohistory/image/Dubonnet Dolphin_01.jpg This computer wouldn't allow the link. If you want to see it,just GOOGLE IMAGES 1934 Dubonnet Dolphin Sorry! |
Here you go:
http://m.blog.hu/au/autohistory/imag...Dolphin_01.jpg Very interesting approach... Those front skirts also look like they are attached to the hub (or some part of the spindle assembly) so that they can turne as the wheels are steered... I'd also guess there is little or no suspension to worry about. |
Another view of the Dubonnet Dolphin
http://i13.servimg.com/u/f13/10/09/09/35/dubonn10.jpg Ironically, Ecomodder is the first hit I get when I search for "Dubonnet Dolphin" ... :cool: |
hub
Thanks again for photos! |
Cool! OK, anyone plan to build one of these? I think it's important to clean up the front aero flow to maximize the impact of boat tails, side skirts, and rear wheel skirts.
