Front Wheel Skirts are a Go!
Since everyone loves front wheel skirts, I felt I should
invite everyone to my '03 Tacoma Prerunner thread to check out the latest install. http://rrrikk.fastmail.fm/Truck/prof...rontskirts.JPG http://rrrikk.fastmail.fm/Truck/sideskeleton2.JPG Questions and Comments are appreciated. I tried to provide a few hi-res pix from different angles, so you can see what I did more easily, but there are a few things you can't tell from the pix. Except for the coroplast, the entire assembly is screwed together from steel straps from Lowe's. ---> My '03 Tacoma Prerunner thread |
Ok, I think the links should work now. Sorry about that. They worked on my computer! :)
Except for the coroplast and the sacrificial cutting board pieces, you mean? ;)
Pretty cool! It'll be interesting to see if/how it helps. -soD |
But no, actually, the "push plates" are pieces of clear acrylic left over from a previous project, also from Lowe's. :) They look like that, because I sprayed them with teflon wax. |
your car looks awsome. much better than the stock pickup
