Old 04-28-2011, 01:56 PM   #1 (permalink)
XJguy's Avatar
Rear window and Airtabs (vortex generators)
Independent test: Positive results.
Autospeed
Old 04-28-2011, 02:02 PM   #2 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
just proves the concept, no measurable effect on FE
Old 04-28-2011, 04:45 PM   #3 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Hi XJguy
Here's another demonstration that Airtab style VG's clearly alter airflow over the rear window of a Toyota Corolla sedan. However they did not measurably improve fuel economy in A-B-A testing (on that car):
See: http://ecomodder.com/forum/showthrea...olla-2390.html
The VG's consume energy (gasoline) to generate their vortices (this was evident to me in the subjective increase in wind noise I noticed in testing) .
So if the application in which they're used isn't ideal (ie. the VG's cause flow to re-attach on the trailing edge of a decklid where it otherwise wouldn't) then they may be of questionable value for fuel economy.
The Corolla decklid was apparently long & high enough, and this combined with the shape of the trailing edge of the roof, meant that the VG's didn't help compared to stock.
