[FS] 92 efi 5 speed
I have a 92 efi 5 speed ford festiva for sale. It's kind of a weird story. I was selling an efi 4 speed for a friend. He liked his prizm better. So I had a long time festiva nut buyer lined up. He described himself as obsessive and continued to push me to buy and install more parts. The short of it is I was stupid and didn't get a deposit and he backed out. I now have a chunk of cheese tied up in it. I need to sell it and try not to lose my shirt. I have receipts. I will consider delivery. 53 mpg is a consistent best from efi 5 speed festivas. You can get 45 w/o trying. The best thing about the festiva though is it's durability. I've seen 10 now with over 500,000 miles. I found 2 in october. One with 465,000 the other with 475,000 both were on the original engine trans AND CLUTCH!
List of parts done last weekend... 1. A five speed trans 2. A new clutch 3. resurfaced flywheel 4. Rotors, hubs, struts from a 105,000 mile festy I parted out 5. New Distributor cap 6. new rotor button 7. new two stage Tstat 8. new timing belt 9. new water pump 10. new rear main seal 11. new front seal 12. new camshaft seal 13. new valve cover gasket 14. new oil and filter 15. new ngk plugs 16. new wires 17. new lower control arms 18. new sway bar bushings 19. vent bezel (stays put but lower right corner is cracked off) 20. used pass. axle from a parts car 21. fresh antifreeze Will be putting on a timing belt tensioner this weekend. It runs great. Current VA inspection. Heat works. Body is mostly straight. The pass fender is a little wrinkled. I have to get $1850 just to almost cover the car and the parts and labor. http://i286.photobucket.com/albums/l...aul/4speed.jpg http://i286.photobucket.com/albums/l...ul/4speed4.jpg http://i286.photobucket.com/albums/l...ul/4speed2.jpg http://i286.photobucket.com/albums/l...ul/4speed3.jpg http://i286.photobucket.com/albums/l...einMass028.jpg http://i286.photobucket.com/albums/l...einMass033.jpg http://i286.photobucket.com/albums/l...einMass009.jpg http://i286.photobucket.com/albums/l...einMass024.jpg http://i286.photobucket.com/albums/l...einMass020.jpg http://i286.photobucket.com/albums/l...einMass002.jpg http://i286.photobucket.com/albums/l...einMass061.jpg |
Paul... this aint ff.com, you might want to retitle the thread "92 efi 5 speed FESTIVA!" :P
mileage?
Unknown. The odometer reads about 150k or so. But the engine and trans are from 2 other cars. Runs right though. Great actually. Forgot to add fuel filter to the new parts list as well.
