FS: 97 VW Passat (B4) TDI 5-spd $650 - Central MN
1 Attachment(s)
50+mpg if you are relaxed ;) 245k , clean title, includes many parts
Cash in person only. Shuttle from MSP $19, I can give you a lift from there. Upgrades and maintenance - Bosio 1019DLC injector nozzles, calibrated set with documentation idparts.com/bosio-dlc-1019-injector-nozzles-set-of-p-6091.html - ECU socketed - Malone ECO tune chipped malonetuning.com/ecu-tuning/audi-volkswagen/tdi/ve-tdi - Frost heater - circulating EBH frostheater.com - Aluminum skidplate evolutionimport.com/odin-skid-plate-kit-for-b4-passat-p/a3004a.htm - Newer timing belt and idler pulleys, ~10k on it - Biodiesel tolerant main seal installed in injector pump head - Transmission oil replaced with oe VW full synthetic gear oil - SMIC delete, included with all plumbing - New parking brake lever and cables - B3 Passat door interiors, manual cranks TO DO - New tires - replace steering wheel clockspring (part included) - recharge A/C - new audio system and speakers, thanks previous owner :/ - 5th gear swap for taller ratio |
