fs d15z1 swap
Currently installed in my del sol with a 4 wire + p07 cali (had smog so my friend wired it up for 4 wire to make sure i would pass).
Coming from a background of racing MPG at this speed isnt for me so my loss is your gain. 110k on block and transmission (VX Tranny) Replaced the following: Water pump timing belt head gasket valve cover seal spark plugs with wires distributor oil pump NTK 5 wire sensor asking $700 with engine harness p07 5 wire ecu (keeping the p07 cali for chipping and tuning) located in socal, garden grove area. Going to pull out the engine this weekend unless i get busy. text me at six two six 417 1979 |
Typo on the price... meant $700 obo
Comes with everything, vx manifold, egr control box, fuel rail, injectors, etc. |
