Fuel injector puller
I fought with pulling a bad injector for about an hour twisting and pulling - actually just tearing up fingers.
Small channel locks were the key! You just have to be careful not to snap off the top. Just wanted to share that tip. |
Often, I'll get a cut pigtail from the same type of injector and use that as ballast to pull it from more than one angle. |
