EcoModder.com
-   Forum News & Feedback (https://ecomodder.com/forum/forum-news-feedback.html)
-   -   Fuel log error (https://ecomodder.com/forum/showthread.php/fuel-log-error-1901.html)
diamondlarry 04-18-2008 12:33 PM
Fuel log error
I screwed up with my last fuel log entry.:o There are two entries for 04/18/2008 and I need to get the one deleted that shows 6.91 gallons.
RH77 04-18-2008 03:18 PM
Maybe the admins can delete the line (?)
Or, on your next fill, just edit the line and enter the updated info (in the meantime, you could put arbitrary numbers in there to better represent you avg).
RH77
TomO 04-18-2008 04:44 PM
IIRC you can just zero out the data and then it will automatically delete the entry at maintenance time (midnightish).
Mike 04-19-2008 03:38 PM
RH77
Unfortunately I cannot access the database *right now* but try setting the values to 0.
