Fuel, speedometer, temp, gauges not working
I have a 1995 Civic VX.
Some of the gauges do not work, initially the speedometer did not work. I replaced it with a used speedometer from another cluster, but then the fuel and temp gauges stopped working, they are stuck maxed out. I read on a honda forum that this may mean that the needles were moved manually, and supposedly this causes ruins the calibration. Does anyone know if this is true? If so is there a way to fix this? i.e. reset calibration or setpoint. If not is there a replacement full cluster I could buy? The OEM is no longer available. |
No longer needed. Selling the car.
