Old 03-14-2008, 08:49 PM   #1 (permalink)
Did you get that thing?
reformed's Avatar
Green Machine - '92 Honda Civic LX
90 day: 39.98 mpg (US)
Money pit - '97 Infiniti j30
90 day: 22.74 mpg (US)
Results are in
Did my first MPG calculation on the Civic today. Its only so-so right now at 33.22... epa combined is 36 so I'm under right now. This is my baseline for the car, even though it has been chilly and its only one fill-up too. I don't have a good average yet, but I'm going to start modding anyway. I just now noticed a small fuel leak that I thought I fixed, so thats part of it, and I haven't changed the plugs, wires, air filter or fuel filter yet, which I'll be doing this week, and I haven't filled the tires to 40psi yet either. So hopefully next tank, I will be above EPA.
Its funny how I have read on this forum about people saying how this site has made them drive more gently. It holds true with me for sure. When I drive that civic around now, I drive like a granny. Its kind of funny to see the look on peoples faces when they fly by you and stare you down like you're the one doing something wrong because you accelerate slow and actually do the speed limit
Here's a question for the honda guys. I've been shifting this car at no more than 2k in any gear, Is there a target shift RPM that will net me better economy on these cars? Also, when I get the VX trans, I know it is geared lower (or numerically higher) for economy, but I also know that the VX engine makes its torque lower in the powerband and so it goes well with its own trans. My question here is: If I mate that trans to my engine, will I cause any undue stress on my engine because of the gearing of the trans?
And here's another, I'm definitely getting a block heater for next winter. Do they do any good in warmer temperatures?.. or am I ok to wait until the temp starts to drop end of summer?
Now that I think about it.. the VX transmissions are geared higher (numerically lower), not vise-versa, I believe.
Old 03-14-2008, 09:11 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
I try to shift as early as I possibly can without lugging the engine to hard or just not going anywhere...Also, the VX tranny should be fine with your engine, it'll make all the world of difference too.
Looking forward to seeing you numbers climb!
Old 03-14-2008, 09:26 PM   #3 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 40.02 mpg (US)
90 day: 49.62 mpg (US)
Let the engine heater wait until end of summer.
Old 03-15-2008, 12:47 AM   #4 (permalink)
reformed's Avatar
Thanks guys. After I get the car tuned up, I think the next project(s) will be to smooth out the underbelly of the car, switch out to a manual rack, and remove the power steering and A/C components. As well as swap the transmission. Anyone recommend any specific spark plugs? or just stick with the factory style?
I found a JDM VX trans that I was thinking about getting, Supposedly it's new, for $275. I'm at the point where I would rather spend a little extra and get something I know is good, rather than take a risk on something used.
What about the VX wheels? does the difference in unsprung weight between those and the stock steelies make enough difference to spend the money?
5th generation civic hatchback - improving aerodynamics AndrewJ Aerodynamics 396 06-13-2022 01:51 PM
E85 - Anyone else getting great results? Rower4VT EcoModding Central 38 05-18-2011 01:10 PM
I've drastically changed my driving style and getting results! Chris D. EcoModding Central 45 07-23-2008 04:13 PM
2008 Pontiac Vibe (Record Results) RH77 General Efficiency Discussion 15 03-07-2008 10:59 AM
Partial Kammback prototype tested - preliminary results MetroMPG Aerodynamics 8 11-28-2007 08:51 AM
