EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   Fun and/or Games (https://ecomodder.com/forum/showthread.php/fun-games-3417.html)
dcb 06-29-2008 02:20 AM
Fun and/or Games
You know you are bored when you find yourself re-implementing conways Game of Life on your mpg gauge :)
http://opengauge.org/diympggauge/life2.JPG
Lot more cells on the 4x20 though
http://opengauge.org/diympggauge/life.JPG
(spoiler) It never ends very well :)
here is the 2x16 code, play with the 1s and 0s in the display[] to set the starting pattern.
PHP Code:
//GPL Software
#include <avr/pgmspace.h>
/* Death
If an occupied cell has 0, 1, 4, 5, 6, 7, or 8 occupied neighbors, the organism dies (0, 1: of loneliness; 4 thru 8: of overcrowding).
Survival
If an occupied cell has two or three neighbors, the organism survives to the next generation.
Birth
If an unoccupied cell has three occupied neighbors, it becomes occupied.
 7 0 1    how I'm referring to neighbors
6_\|/_
  /|\  2
 5 4 3
#define brightness 180 //middle button cycles through these brightness settings
#define contrast 15
//LCD Pins
#define DIPin 4 // register select RS
#define DB4Pin 7
#define DB5Pin 8
#define DB6Pin 12
#define DB7Pin 13
#define ContrastPin 6
#define EnablePin 5
#define BrightnessPin 9 //control with a transistor please if you use it
typedef void (* genericFx)(void);//type for function pointers
genericFx resetFunc 0;
//LCD prototype
class LCD{
public:
LCD( ) ;
void gotoXY(byte xbyte y);
void print(char string);
void init();
void tickleEnable();
void cmdWriteSet();
void LcdCommandWrite(byte value);
void LcdDataWrite(byte value);
byte pushNibble(byte value);
LCD lcd;
int powerUp MCUSR &1;  //did we reset or power up?
#define rows 6
#define columns 16
byte tmp [] = {
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
byte display [] = {
0,0,1,1,0,0,0,0,0,0,0,0,0,0,0,0
0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1
0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0
0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,
void loop (void){
lcd.init();
byte running=1
  while(
running==1){
unsigned long loopStart=millis();
running=0
//  update the neighbor counts
for(int y 0rowsy++){
      for(
int x 0columnsx++)
tmp[y*columns+x]=getNeighborCount(display,x,y);
//display the array
for(int y 0rowsy+=3){
lcd.gotoXY(0,y/3);
      for(
int x 0columnsx++){
byte n1=display[y*columns+x];
byte n2=getNeighbor(display,x,y,4)*2
byte n3=getNeighbor(display,x,y+1,4)*4
lcd.LcdDataWrite(n1|n2|n3);
//see who lives and who dies
      for(
int x 0columnsx++){
byte b display[y*columns+x];
byte n tmp[y*columns+x];
        if(
b==0){
          if(
n==3) {
display[y*columns+x] = 1//birth
running=1
        }else{
          if(
n==|| n==3)
display[y*columns+x] = 1//survival
else {
display[y*columns+x] = 0//death
running 1
lcd.gotoXY(0,0);
lcd.print("DONE");
delay(1500);
resetFunc(); //poor mans reset :)
byte getNeighborCount(byte a[], byte xbyte y){
byte c 0
  for(
byte d 0;8d++)
    if(
getNeighbor(a,x,y,d) != 0
c++;
  return
c
byte getNeighbor(byte a[], byte xbyte ybyte dir){
byte nx=x
byte ny=y
  if(
dir == || dir == || dir == 1)
ny--;
  if(
dir == || dir == || dir == 5)
ny++;
  if(
dir == || dir == || dir == 7)
nx--;
  if(
dir == || dir == || dir == 3)
nx++;
  if(
nx==255nx columns 1
  if(
nx==columnsnx 0
  if(
ny==255ny rows 1
  if(
ny==rowsny 0
  return
a[ny*columns+nx];
//get a string from flash
char mBuff[17];//used by getStr
char getStr(prog_char str){
strcpy_P(mBuffstr);
  return
mBuff;
//LCD functions
LCD::LCD(){
//x=0..16, y= 0..1
void LCD::gotoXY(byte xbyte y){
byte dr=x+0x80;
  if (
y==1)
dr += 0x40;
  if (
y==2)
dr += 0x14;
  if (
y==3)
dr += 0x54;
lcd.LcdCommandWrite(dr);
void LCD::print(char string){
byte x 0;
char c string[x];
  while(
!= 0){
lcd.LcdDataWrite(c);
x++;
string[x];
//do the lcd initialization voodoo
void LCD::init(){
LcdCommandWrite(B00000010);  // 4 bit operation
LcdCommandWrite(B00101000);// 4-bit interface, 2 display lines, 5x8 font
LcdCommandWrite(B00001100);  // display control:
LcdCommandWrite(B00000110);  // entry mode set: increment automatically, no display shift
//creating the custom fonts:
LcdCommandWrite(B01000000);  // set cgram
static byte chars[] PROGMEM ={
B00000,B11111,B00000,B11111,B00000,B11111,B00000,B11111,
B00000,B00000,B00000,B00000,B00000,B00000,B00000,B00000,
B00000,B00000,B11111,B11111,B00000,B00000,B11111,B11111,
B00000,B00000,B00000,B00000,B11111,B11111,B11111,B11111,
B00000,B00000,B00000,B00000,B11111,B11111,B11111,B11111};
    for(
byte x=0;x<8;x++)
      for(
byte y=0;y<8;y++)
LcdDataWrite(pgm_read_byte(&chars[y*8+x])); //write the character data to the character generator ram
LcdCommandWrite(B00000001);  // clear display, set cursor position to zero
LcdCommandWrite(B10000000);  // set dram to zero
void  LCD::tickleEnable(){
// send a pulse to enable
digitalWrite(EnablePin,HIGH);
delayMicroseconds(1);  // pause 1 ms according to datasheet
digitalWrite(EnablePin,LOW);
void LCD::cmdWriteSet(){
digitalWrite(DIPin,0);
byte LCD::pushNibble(byte value){
digitalWrite(DB7Pinvalue 128);
value <<= 1;
digitalWrite(DB6Pinvalue 128);
value <<= 1;
digitalWrite(DB5Pinvalue 128);
value <<= 1;
digitalWrite(DB4Pinvalue 128);
value <<= 1;
  return
value;
void LCD::LcdCommandWrite(byte value){
value=pushNibble(value);
cmdWriteSet();
tickleEnable();
cmdWriteSet();
tickleEnable();
delay(1);
void LCD::LcdDataWrite(byte value){
digitalWrite(DIPinHIGH);
tickleEnable();
tickleEnable();
delay(1);
void setup (void){
MCUSR=0
Serial.begin(9600);
pinMode(BrightnessPin,OUTPUT);
analogWrite(BrightnessPin,255-brightness);
delay(500);
pinMode(EnablePin,OUTPUT);
pinMode(DIPin,OUTPUT);
pinMode(DB4Pin,OUTPUT);
pinMode(DB5Pin,OUTPUT);
pinMode(DB6Pin,OUTPUT);
pinMode(DB7Pin,OUTPUT);
delay(500);
  if(
powerUp)
lcd.init();
pinMode(ContrastPin,OUTPUT);
analogWrite(ContrastPin,contrast);
lcd.LcdCommandWrite(B00000001);  // clear display, set cursor position to zero
lcd.LcdCommandWrite(B10000000);  // set dram to zero
lcd.gotoXY(0,0);
lcd.print(getStr(PSTR("Game of Life")));
lcd.gotoXY(0,1);
lcd.print(getStr(PSTR("  mpguino style")));
delay(1500);
