FYI: Harbor Freight Trailer Bearings/Hubs
I gave the wheels on my Harbor Freight trailer a spin the other day and one of them felt a bit rough. Upon disassembly, I found the inner bearing had been smoked. So it was off to the local parts store for a regular old 1 inch spindle bearing kit.
Oops. This trailer doesn't have a 1 inch spindle. It has a 25mm spindle. And instead of a 1.98" OD cup, it has a 52mm OD cup (2.05"). That's a big enough difference to not work. The regular old seal doesn't fit either. I have purchased new bearings from a local bearing supplier and I have purchased extras in case of a break down in the future. Most of my info comes from here: Folding Utility Trailers, Trailer Kits, Parts and Accessories - RedTrailers.com Bearing assembly part #30205 (your local bearing supplier should understand this number) Seal part #30-52-10 |
That "grease" that comes with the made in china bearings isn't real load bearing EP grease. Its just gunk that keeps the rust off the bearings and race surfaces during the boat ride over here.
So when you get new bearings do not install them. Remove the gunk from them and repack with real lithium based grease that actually has extreme pressure additives in it. If you do not clean and repack the new bearings you will need all the extras you bought and then some. |
regards mech |
I have historical had hit or miss luck with imported bearing sets. Some Korean, Chinese manufactured ones will hold up others not so much. And the same manufacturer can be inconsistent on one lot to the next. To be honest its become one of those things that I pay more for a U.S. based producer. Which are few and 3 times the price.
The made in china outer front wheel bearing on my car had its bearings outer coating start to flake off after being on there for about 8 years. I greased them numerous time over those years. During those 8 years the car was sitting most of that time.
I replaced them with some that were made in japan. |
