Old 02-28-2013, 05:45 PM   #1 (permalink)
Vacuum gauge Mitsubishi Lancer
Hello!
I bought a mechanical vacuum gauge with a T connector. I searched on alot of places but I really cant decide which hose to connect the T in?
I found a shabby picture of the exact car that I have.
View image: bild
I think that I should plug it in somewhere around the ECI MULTI but is there anyone who can say which line is correct? I dont want to break a fuel line or something!
Thanks!
Greetings from cold sweden!
Old 03-01-2013, 10:08 AM   #2 (permalink)
Runs with scissors
Spot - '05 Scion XA
90 day: 30.33 mpg (US)
Green arrows show the way
The most reliable source of manifold vacuum is the brake booster hose. You will probably need to buy a tee that will adapt between sizes. Be sure to use clamps so you don't lose brake vacuum when you need it the most .
[IMG][/IMG]
Old 03-01-2013, 05:38 PM   #3 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Usually any line that has a high vacuum at idle is good. As long as your show a vacuum at cruise that goes to zero at full throttle you probably can use the gauge as it is just a relative indicator of engine load.
The power brake line is a good source but I usually refrain from cutting into that line in the interest of brake reliability.
Look for a line that goes into the intake manifold some place rather than into the air body.
Noah Webster, 1787
Old 03-01-2013, 06:38 PM   #4 (permalink)
Do more with less
This looks like a good place to Tee into.
Noah Webster, 1787
