EcoModder.com
-   The Unicorn Corral (https://ecomodder.com/forum/unicorn-corral.html)
-   -   "The Gas Saving Switch" (https://ecomodder.com/forum/showthread.php/gas-saving-switch-31157.html)
ECONORAM 02-06-2015 10:12 PM
Found another one today. It claims to cut your fuel use by 5.5 gallons from every 10 gallons. So, a 55% (or is that 110%) increase in fuel economy, by some device you plug into your OBD port? Right....
I highly doubt anything you plug into your vehicle OBD port will increase your fuel economy by even 50% in only 30 minutes. Even if you could adjust your fuel mixture to full lean (i.e. 16:1), you’d only get about 20%.
I did some searches, but that turned up the original video linked site, and some "reviews" that were a verbatim copy of the original site text, with some picture variations. Gas-Savings-Switch.com
gas-savings-switch.com
mcrews 02-06-2015 10:54 PM
There has been a obd one and one for the cigs rattle lighter. They are both junk.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
