DDG says 3.5 quarts. I'm Okay with Walmart since Amazon is bigger and badder, but I've seen things on their website that aren't available in the brick and mortar store.
My question is how would I know the difference with few miles driven. Would it sound quieter?
For 3.5 quarts, you need ~100 grams of boric acid.
Instructions:
You want ~350ml of boiling water.
Stir in about 100g of boric acid. The first ~60g will dissolve easily — no need for it to be super fine.
That will leave 1–2 teaspoons of undissolved boric acid at the bottom.
This undissolved part should preferably be finely ground (coffee grinder, freezer trick) so it stays in suspension better and more passes through the oil filter.
Use a thermos or something quick to open without burning yourself.
Pre-heat it with boiling water, that you pour it out before it holds your mixture.
Shake the mixture well just before pouring, to get the undissolved powder into suspension.
Bring a spoon for any powder left in the bottem.
Add it to an engine that’s topped up with oil and warmed up.
Drive of immediately but gently for 10–15 km because the oil will be thinner temporarily.
You will feel it kick in:
The engine smooths out and more pep.
You can then drive normally (or really test it properly! 😉
Advice:
The safe approach:
Do this with new oil, after an engine flush to clear out any sludge.
(Using different oil brands can make a lot)
This stuff gets underneath sludge like nothing else, loosening it.
The sludge could block your oil pump pickup and/or filter.
Change the filter again after ~2 days.
At minimum:
You should change the oil filter before and do a proper oil service within ~2 days.
The coffee grinder, freezer trick:
You put your BA in the coffee grinder, then the whole ting in the bottem of the freezer for a good couple of hours.
This makes the powder brittle (freezes any moisture) and the coffee grinder more effective.
Take the grinder out and run a couple of bursts, while turning it this way and that.
Repeat.
When the powder becomes so thin it sticks to the lid, obscuring your view, you're about done.
Takes 2-3 goes.
