EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Gen 3 Gas Tank Too Small. (https://ecomodder.com/forum/showthread.php/gen-3-gas-tank-too-small-36562.html)
Angel And The Wolf 06-18-2018 09:54 PM
Here in Texas, United/Market Street Supermarkets award a point for each dollar you spend. Each 100 points get you 10 cents of every gallon of gasoline you get at their gas stations (up to 25 gallons) Trouble is, I throw away the savings on the extra 15 gallons I can't fit into my 10 gallon tank. I'm thinking of buying three 5 gallon Jerry cans to finish out my 25 gallons, and going to the pump 2 1/2 times less often, with the bonus of building my points to 50 cents off the price of a gallon. Is there a better way?
oil pan 4 06-18-2018 10:21 PM
Got a gas can?
You might be able to find a few cheap ones at yard sales.
M_a_t_t 06-18-2018 11:00 PM
When I can I go with my mother to the gas station to use some of the cheaper gas. I've only done it with my motorcycle and her car as of yet.
Xist 06-18-2018 11:38 PM
How much gas can you transfer from the can without spilling?
Mom and I fill up at the same time, with the same discount. The first time we set down the nozzle. The second time Mom fueled and I moved each car.
I move much faster than she does.
Angel And The Wolf 06-18-2018 11:56 PM
Originally Posted by oil pan 4 (Post 572352)
Got a gas can?
I was hoping someone would point me to a place where I can get a larger replacement tank, or an auxiliary tank to add to the car.
19bonestock88 06-19-2018 12:08 AM
I’m curious about this myself, as my car only holds 12 gallons max and I’d also like to double that... only thing I can think of is fabricating a bigger fuel cell to fit in the same space/take advantage of empty space under the car
oil pan 4 06-19-2018 01:06 AM
As long as you are not drunk no one should be spilling more than a tea spoon or 2 of gas. If someone can't put gas from a gas can into a car with out spilling it every where they probably shouldn't be driving a car.
Cars stopped having options for a larger gas tanks in the 1970 as far as I know.
You could add a few cell but it would be installed inside the car and would cost several hundreds of dollars. If not more to do it right.
Angel And The Wolf 06-19-2018 01:21 AM
Yeah, I could put it in the spare tire well, but with that traction battery and the 12 V battery so close, I'm not sure how safe that would be.
oil pan 4 06-19-2018 01:26 AM
A car with an unprotected gas tank, think ford pinto or old F100 with side gas tanks.
Xist 06-19-2018 02:05 AM
There is a large difference between spilling a teaspoon or two and an entire can.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
