Gen 3 Prius See Through Boat tail Idea
I used the template, both vertically and horizontally to draw an aerodynamic boat tail.
The floor, end piece, and front is plywood, and the sides and top are clear plexiglas pulled into curves that match the template. The floor is bolted to a trailer hitch ball mount, and the plexiglas is built on the plywood pieces. I also plan a plexiglas piece that would stretch from the top of the rear hatch window to lay on the flip up part of the spoiler, thus allowing the air to flow without the flip at the rear. I doubt I will be driving at a speed where I might need a spoiler. The boat tail will reduce the vertical area to about 144 square inches, 6" high X 24" long. |
Well, I have drawings, but I seem to have misplaced the attachments button.
6 Attachment(s)
OK, here are the drawings:
http://ecomodder.com/forum/attachmen...3&d=1517906764 http://ecomodder.com/forum/attachmen...4&d=1517906779 http://ecomodder.com/forum/attachmen...5&d=1517906795 http://ecomodder.com/forum/attachmen...6&d=1517906813 http://ecomodder.com/forum/attachmen...7&d=1517906835 http://ecomodder.com/forum/attachmen...8&d=1517906857 |
1 Attachment(s)
I worry a bit about the necessarily high angle of the plywood floor, that it may produce such a reverse lift that the front of the car becomes lighter.
I hate to use anything to direct the air toward the floor that would increase drag. Maybe a second floor skin hinged at the front of the tail that could be drawn downward by the lower pressure? http://ecomodder.com/forum/attachmen...9&d=1517925907 |
1 Attachment(s)
Or, maybe just a spring loaded second floor, without the end or side pieces. At slow speeds, where you would be enter driveways, the second floor would be held up against the real floor by the spring loaded hinges, but at higher speed, where reverse lift would be produced under the boat tail, the second floor is drawn down by the lower pressure, and keeps the lower pressure off the real floor.
Would this work? http://ecomodder.com/forum/attachmen...1&d=1517938802 |
1 Attachment(s)
Or, maybe I should leave the sides on the second door to keep down spill over?
http://ecomodder.com/forum/attachmen...2&d=1517939704 |
http://ecomodder.com/forum/attachmen...p;d=1517906779
I'm no fan of The Template, but get some other opinion on whether you have applied it correctly. The top view Template[s] are complete, but the side view is butchered. The ground plane and departure angle have been deleted. What you have is suitable for off-road rock crawling. IMHO it should also slide forward to match the contour at the roof. I know you're fixated on reducing down to the height, if not width of a license plate. You're compromising a lot to get there. |
1 Attachment(s)
http://ecomodder.com/forum/attachmen...8&d=1517944910 |
Just trying to help. People apply the template to everything. The thing is the back 70% depends on the airflow set up by the forward 30%. You can't just tack it onto the back of some arbitrary form. Mair starts with an extended body (fineness ratio is your friend) with a circular cross-section. There is (somewhere) some middle ground, hence the wind tunnel rules over theory.
http://ecomodder.com/forum/member-fr...perellipse.jpg I like the Tropfenwagen, it's shaped like a submarine conning tower. I tried combining several aero-forms into one: http://ecomodder.com/forum/member-fr...15-4-45-47.png This would need serious filleting and tweaking, but could accommodate specific internal space requirements. You could lose all the [upper] taper and optimize the sides. Here's a study of putting a back window like the 1948 Studebaker Starlight coupe on a Beetle: https://i.imgur.com/YHtUq.png |
If you do go in the direction of a retractable floor, look at the rear door of the P-51 Mustang. ;) http://www.ipmsstockholm.org/magazin..._p51_f_004.jpg As far as yer choice in materials, you might want to look at Coroplast and aluminum angle to build out the floor pan with instead of plywood. Waterproof and there isn't a propensity to degrade with inclement weather. It will be lighter and more durable than plywood. It will last longer and be easier to work with and install. ;) I'm not sure you would want the upper part to be plexiglass as the suggested angle you have would make it rather difficult to see out of especially as the thickness increases. ;) |
After studying the design a bit more, I'm thinking the second floor idea is more trouble than it's worth. I may just have to employ a gear driven lower-able wing to combat rear suck down at speed, and dropping from near the bumper into the airstream. Unlike the usual wing on cars, which applies a down force at speed to combat lift, this one would apply lift at speed to combat down force created under the boat tail. Perhaps the wing could be operated mechanically by the change in the distance between the rear axle beam, and the car under body. You know, I'm just brainstorming, don't you? Thanks for the Coroplast suggestion. |
1 Attachment(s)
Maybe I'm looking at it wrongly. Instead of trying to holds the rear up, maybe I should put a wing in front of the grill to push the front down.
aerohead's verdict. Note the max camber is centered on the driver's door and the nose is at the front wheel. |
attached airflow
Also,I don't think the photo of the Prius is true-length,as in a blueprint.The camera appears to be looking from a forward-biased location,which would throw off any template alignment. |
wing
I would recommend that you put your effort into cleaning up the belly and rear wheel openings to guarantee quality flow to the boat tail.Then see if you can figure out how to get the 'final' diffuser angle as close to 2.8-degrees as you can. If the bottom of the tail is steep,it will create high-drag,attached,counter-rotating longitudinal vortices below the tail; and probably enough turbulence to cause flutter. |
When you address the underbody everything will be dependent on the size and offset of the four tires protruding into the air flow.
http://www.tacomaworld.com/forum/tir...155x70xR19.pnghttp://www.tacomaworld.com/forum/tir...155x70xR19.pnghttp://ecomodder.com/forum/showthrea...res-25208.html I'd consider fitting BMW i3 tires (w/ appropriate wheels) with an offset such that they flush to the standard body panels. aerohead appreciates a round air intake at the stagnation point. http://ecomodder.com/forum/member-fr...7-12-29-57.png That Photochop was intended for a VW flat fourin front. With the stock Prius drivetrain it needn't be any bigger than this: http://ecomodder.com/forum/member-fr...1-100-1194.jpg |
template/photo aligment
Really accurate photos are shot with a telephoto lens from at least 200-meters away from the vehicle and produce an image close to what you'd see with a technical image (blueprint).I think your photo was shot much closer to the car,was elevated,and was towards the front of the car,rather than from its geometric center.This will throw things off when attempting to use the template tool. |
OK, I'll shoot my own.
The passenger door window should be perfectly centered in the driver's door window, if you do.
But if you have an adequate computer to run 3D modeling software you could use one of these free models and add your designs to it. https://www.stlfinder.com/3dmodels/p...del-comparison https://www.3dcadbrowser.com/th/1/15/15310.jpg https://www.cgstudio.com/imgd/l/541d...a016b/1379.jpg My system needs upgrading, I'm struggling to bring a new machine up under the threat of Spectre, Meltdown and BadUSB. I think I need a hardware firewall. When I did have it together I couldn't merge my modelling with the download, but it was adequate for pulling dimensions. It looked like this: http://ecomodder.com/forum/member-fr...four-tails.jpg |
4 Attachment(s)
Attachment 23475OK, I think I've figured out how to do the 2.8 degree, and still get clearance for driveways:
Oh, in answer to someone telling me Plexiglas wouldn't be good for looking through when curved, I'll build the tail opaque, and mount rear view cameras in it. |
I use a variety of methods. I assembled this to show these steps:
http://ecomodder.com/forum/member-fr...how-sketch.jpg The original picture was cut up in Photoshop for step 2. Step three was putting tracing paper over the screen and doing a pencil sketch, which was scanned back in. The final step was done back in Photoshop. In practice the bubble windshield would be three flat facets. |
It's a poor workman that blames his tools, but the 3D software is borked and the scanner is long gone. :( I'm coasting on fumes.
I bought Photoshop Elements at a Goodwill for IIRC $8.00. |
