Geo Metro Fast Idle Problem?
anyone had a fast Idle problem with there metro 1.0 engine? If so How did you fix it. :(
is this intermittent? just happen during the cold months?
i bought a 26yr old used accord, it was idled too high from the day i bought it last august. it was consistently too high, even for the warm months. i found two screws under the carb that allowed me to drop it to about 500rpms. you may have a fuel injected engine, but if your idle is consistently too high, even after it has warmed-up, i;d try to find the idle screw or a chilton book to point it out. i have noticed that on rare occasions my car may idle too high. i place my foot under the accelerator and lift the pedal to lower the rpms. this is very rare that i experience this, but i assume it's linkage. i hope this helps. |
What year Metro? You shouldn't have to screw around with the idle adjustment unless somebody else has screwed around with it first. Check for vacuum leaks.
If it's a 1989-1995 engine then read this thread................
High Idle |
