EcoModder.com
-   -   Geo Metro Kill Switch Idea? (https://ecomodder.com/forum/showthread.php/geo-metro-kill-switch-idea-1350.html)
HotRod 03-10-2008 06:44 PM
I am trying to rack my brain of a less anoying way to kill the engine for EOC. Currently it's set up like this. Turn key to off "BEEP!>>>BEEP!>>>BEEP!"; after 5 seconds, turn to run "BEEEEEEEEEEEEEEEEEEEEEP"!
AAAAHHHHH!
It's freakin loud and terribly anoying.
So, (sigh) this is what I was thinking...
1. going to the engine fuse
2. remove fuse and run a set of wires, one on each side of the empty socket
3. run wires to a simple switch located where ever is most conveniant.
4. run an inline fuse (to replace the old one) so as not to expose the circuit.
5. Simply hit the toggle switch for a couple seconds and then flip is back.
What I am worried about is whether that would be hard on the engine/computer to use this method. What am i not thinking of?:confused:
HotRod 03-10-2008 08:01 PM
Crap, should have search the forum before I posted.
I see AndrewJ already did this...right when I thought that i thought a thought...
s2man 03-11-2008 02:05 AM
I thought he did... :D
jwxr7 03-11-2008 01:27 PM
I put a normally closed momentary push button in series with my fuel injector to kill my engine. It works very well and the computer doesn't seem to mind. I like it better than just cutting off spark because no unused fuel is wasted :). It bump starts instantly too.
SirKeats 07-28-2008 12:43 PM
i'm having trouble finding andrew's thread on this. looking for a how too so i can run a switch myself. can someone point me in the right direction?
thanks!
drbobwoolery 01-27-2011 07:13 PM
I'm off to pick u part to get a FI resistor and its connector. Mine measures 2 ohms, but I want to make an adapter cable to bring the kill switch and both sides of the resistor into the cab. That way you aren't bypassing a fuse, cutting into wires or any of that. If a setup doesn't work, unplug the adapter and you are back to stock. Stock is important for California smog tests.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
