Geo Tracker help ?? Tracker owners?
Ok I want to get a geo tracker. I sat in one in the pick and pull and was AMAZING how comfortable it is compared to my Geo Metro.
I understand its essentially a suzuki sidekick like my metro is a swift?? I am look at a 4wd 4cyl AUTO (drat) I am pretty decent at squeezing mpg's out of my cars. I can squeeze 60mpg daily out of my xfi on E10 even with the trailer attached. I was able to ring 25.5mpg out of my pops 8cyl towncar and this included 3 trips into center city philadelphia. (or I would have gotten 26.5 27mpg i think) My typical commute is 54miles one way few stops average max speed around 45mph (yes I drive slow to save gas) the only time I do 50mph (the PSL) is when someone is behind me and they can not pass (I don't like to be rude) so you tracker owners. what do you estimate i might be able to wring out of this tracker at those figures? basically the plan is Metro spring and fall and winter. the Tracker when there is snow or when its JUST too hot to be without AC. do you think I can best 30mpg? tickle 35mpg? Next question How difficult would a 5speed swap be? its not "too" bad in a metro. how hard in a tracker? (I have never done either) how about a 3cyl swap? ie put a metro 3cyl engine into the tracker? Why the auto? well around here trackers might as well be made of freaking GOLD for the going price of them. I found one 4wd auto for $900 so it peaked my interest. |
i have one well two, my runner was 2wd when i got it. i got one for parts that was 4wd.
ALL 4WD PARTS WHERE BOLT ON, NO WELDING AT ALL so a 4wd can be changed to a 2wd just as easy as i went from 2wd to 4wd. that is as long as your doner auto has the same trans and engine to keep gearing the same. 4wd springs are about 1\2" taller giving the 2wds a gvw rating of 100lbs less than the 4wd. also there about 3,000LBs the 1.6L 16V makes about 60hp per L of displacement quite good for its 1992. there's a massive amount of room for improvement in the aro area in the rear of the auto. the back window gets dirty on a rock road VERY FAST. this is somthing i have yet to even play with gearing for them ranges from 4.30s with the 3speed auto trans common in the 2 doors. to 5.833 gears in very rare 88\89 models as far as my mpg it ranges from 22 when it was running on three pistons, too 33mpg going all out for mpg with E0 gas. with a few 3 to 5.5K mountain passes mixed in.... epa highway is 26 under the old rating system. i got 24 mpg once pulling a 2,500LB U-hall trailer running it as a 4sp, when i used 5th as top gear in flat land i got 22mpg mine has the 5sp with 5.125 gears. Quote:
looking at different autos on the road, i think the early kia suv would do much better in regards to aro, compared to the sidekick. but ive never driven one so ive not had the chance to find out the LBs of one....or what kind of mpg they get.
difference is the kia has a 2.0L engine versus the TBI 8V or EFI 16V 1.6L or in real early ones TBI 8V 1.3L in the sidekick the kias 4wd hubs work on vac to engage, where the sidekick uses true old school auto hubs or manuals. after 15 years its easier just to change to manuals then deal with the VAC ones. bolth use a rear drive, front engine lay out, just like a truck. makes working on it very easy. compared to front drive. granted my runner is stock with no A\C also its not that bad to drive with the P\S belt off being a lighter auto:D but man with 50psi it rides like a dang buck board. but i just live with it.... |
im guessing you did'ent get it or....?
I had a 93. 4 inch body lift and 2 inch suspension lift. 33x12.5 tires on 15x10 ford f150 rims. 5.13 gears. 5 speed. If cruising around town it's a beautiful drive. The bigger tires, if you learnto drive with make the truck more comfortable and the engine rev lower. The drivetrain is unkillable. Auto hubs are awesome despite some fans claiming they are weak, I never broke one. Mpg... Not bad for an offroad truck. Had to draft 18 wheelers on the highway, Or else it was pedal to the metal. Literarily, just to keep up with traffic. Had a snore at the top of windshield, I think it helped. Compared to my v8 TransAm at the same time mileage was good even with big tires. In three years I only busted the front axle housing once. My fault. The front was really really stuck and I applied full power.
If you want to Eco mod it slap on some tall skinny tires you'll do alright. The 33 inch mud tires i ran at 16 psi Somehing skin y you could run at higher pressure the truck would like it I once got 30 mpg out of a stock 95 16valve 5speed truck racing home from2 hours away. |
i think there's a lot to gane in the aro of sidekicks.
the back end is very un aro. small narrow tires, clutch fan deletion, with the gears from a auto the 4.60 or the 4.30s behind the 25% O\D manual trans, i think one would push near 40 mpg. convert one to 2wd and you will shed about 150\200LBs use the 2wd springs and lower the ride a 1\2" |
wow. old thread. I FINALLY got one. 1989 non vert 4x4 with ac and 5 speed.
http://i.imgur.com/lzCYFjNl.jpg First tank 28.60mpg second tank 31.72mpg and I have a bad exhaust and its winter blend below freezing temps. I am going to have a TON of fun with this critter :-) |
wow hard top 2 door "very rare"..
i think there about 2,600lbs or there abouts. 4 doors are about 3,000lbs so is it the 1.3 8V carb 1.6 8V TBI or has it been swapped to the EFI 1.6L 16V that came out in 1992? for the most part the 8 valves where rated about 2 more mpg then the 16V i think a geo 1.0L engine would fit the trans if it is in need of a new engine. that would be about 1/2~ the hp of the EFI 1.6L 16V so far my best is 35mpg in a 4 door 4wd 5sp (no aro mods at all). in a two door you should beat that with ease.... |
boy I wish their was a 1.3 TBI. it is definately FI so must be the 1.6 8v or 16v I hope its the 8v. probably is got it from the original 1989 owner and the engine was not replaced.
geo engine will fit but not "mate" right to the tranny. (top bolt will made need custom drilling to mate the other 2) from what I understand. but I think a G10 would be too weak for this. that's what my XFI is for :-) I am very pleased to be hitting near 32mpg in winter on winter blend sub freezing with a goofy exhaust and probably needing valves or a valve adjustment. very please. I think your right beating 35 should be very doable once its warmer especially the way I drive (45mph everywhere :-) |
watch for a 2 door with the 3sp auto there the ones with the 4.30 gears.
a 4 door with 4speed auto is the 4.62 most of the time. the 5speeds in 1989 are any where from 5.12 to 5.88s gears im about 3,000rpms or a smite less at 60 in top gear with bald 215/75/15LT i figure it has the 5.12s being a 1993 only the 1.6 16V is EFI it has the trade mark (pane in the rear) 5" deep spark plug holes :( sence 92 was its first year you dont have it.... the 1.6L 8V has the spark plugs on the side of the head, its TBI about 80hp for the 8V and 95 for the 16V that's some staggering numbers for a 1.6L N\A engine in 1992 if you think about it. thats just under 60hp per L of displacement for the 16V 50hp for the 8V only the 1.3L is true carb, its more common in the Sammy then the track/kick |
Here are the two engines.
8 valve TBI http://carphotos.cardomain.com/ride_...0010_large.jpg 16 valve MPFI the red arrows point out the "16 valve" logos. http://www.suzuki-forums.com/attachm...-valve-16v.jpg You must have a very economical route because the 20*f morning commute nets me about 26mpg. Over a tank I get 28-29mpg. |
I guess if you do not plan to tow you could switch out the rear end gears for a higher ratio, but if its 4wd, you got to do both.
Ive toyed with that idea since it runs high rpms at highway speeds. Of course it would loose its towing ability, but I thought I would shift to 4wl for that. I know it says niot to use 4wd on pavement, but my tacoma said its max towing capacity was in 4wd. :confused: |
Geo trackers weren't meant to tow. Doesn't mean people don't but since these vehicles weigh a little over 2000 lbs towing would be iffy...
There have been people that swap out the 5 speed diffs for the diffs found in the autos in order to get the revs down but quickly realized that 5th gear became almost useless. These little engines just don't have the torque to be playing with gears like that. Also you aren't suppose to use 4WD on pavement for a reason. Binding up the driveline is the fastest way to break something. Yes it is possible to drive on pavement in 4WD but Use it only at low speeds...you have to be extremely careful and not to turn the wheel much. Also when you turn the wheel you need to let the driveline tell you how much you can.. Feel the wheel go back and forth by itself you will know what I mean. Forcing it will bind it up. If you have to make a sharp turn you need to pop it back in to 2WD. Before I had my NP242 T case with 4WD full time in my Jeep I used to have the NP231 and used 4WD part time during nasty winter days since the added traction was necessary... I did the above and luckily didn't break anything. |
As is with the larger tires 5th gear acts more like an over drive for 45-55 mph. Otherwise I find I need to go to 4th when the going get tough.
The idea in the stock configuration of tires was to switch out the ring and diff gears in the car for a higher ratio, then when you wanted lower ratios shift to 4wd low. :eek: I havent driven the kick that much. My tacoma I had I did 10 thousand miles. When it was raining or slick out I shifted to 4wd with no problems, then back to 2wd in parking lots. :turtle: |
