EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   GM & others Reduced I.C.E. Friction (https://ecomodder.com/forum/showthread.php/gm-others-reduced-i-c-e-friction-25060.html)
DIMS 02-26-2013 06:21 PM
Link
Very slick: Automakers strive to reduce engine friction - NWautos
General Motors has quantified the overall friction reduction for three of its four-cylinder engines. The 2007 2.4-liter four-cylinder generated 46 percent less friction in low-speed driving than GM's 2-liter four-cylinder of the early 1980s, despite having more valves, a more complex camshaft drive and a pair of counterbalancer shafts. Friction reduction alone resulted in about 7 percent better fuel economy over that 24-year period.
In the new 2.5-liter four-cylinder that will power the 2013 Chevrolet Malibu, friction has been cut another 16 percent, resulting in a 2 percent engine efficiency gain compared with the 2007 2.4-liter.
Each engine developed more power per liter than its predecessor, doing more
MetroMPG 02-27-2013 03:07 PM
Interesting - thanks for posting that.
Friction reduction approaches mentioned in the article:
  • cylinder-coating materials
    In the Nanoslide coating process, the cylinder walls are sprayed with an ultrathin layer of a molten iron-carbon alloy. A special finishing process puts a smooth surface on this extremely hard coating, at the same time opening tiny pockets in the metal that retain oil for lubrication.
  • advanced honing techniques (abrasive & laser based)
  • smaller bearings
  • straighter chain runs (camshaft chain)
cRiPpLe_rOoStEr 02-28-2013 12:14 AM
Internal coatings, optimization of the design of certain moving parts such as valve rockers, camshafts, among others, and also lighter alloys were a great advance.
niky 02-28-2013 07:20 AM
One problem... these new anti-friction coatings and the lightweight engine blocks mean that re-boring and re-building these engines after they blow is sometimes a problem.
On the brighter side, engines nowadays typically last longer than most people keep cars.
cRiPpLe_rOoStEr 03-01-2013 12:20 AM
That's a good point to consider while looking for cylinder sleeves...
gone-ot 03-01-2013 10:16 AM
...it's also a contention point when something goes wrong with the engine and they want to just "rebore' rather than replace the block under the warrantee!
