Old 10-15-2008, 07:38 AM   #1 (permalink)
Taurus - '99 Ford Taurus SE
90 day: 17.89 mpg (US)
Windstar1 - '97 Ford Windstar Cargo
90 day: 16.99 mpg (US)
Vulcan - '97 Kawasaki Vulcan 750
90 day: 45.96 mpg (US)
Suzuki - '09 Suzuki SX4 Technology AWD
90 day: 24.62 mpg (US)
> Sunmitomo Htr T4
any one have experiences with these? im looking for cheap tires for my jeep zj
also anyone have any thoughts about putting p215 70 15s on my rims. the current tires are 235 75 15
and im pretty sure OEM is 225 70 15
Old 10-16-2008, 02:54 AM   #2 (permalink)
Danger Ranger - '01 Ford Ranger Edge 4x4
90 day: 14.52 mpg (US)
Moms car - '05 Ford Freestyle Limited
90 day: 21.92 mpg (US)
Mistress - '10 Harley-Davidson 883 Sportster 883 Iron
90 day: 42.53 mpg (US)
Send a message via AIM to meemooer
i think it would depend on how wide your rims are, plus they will be shorter, so your gearing will differ
Randy
Old 10-16-2008, 07:44 AM   #3 (permalink)
is there a way to tell how wide a rim is? i have no clue where to search.
this is a factory rim on a jeep grand cherokee limited
is what it looks like.
Old 10-16-2008, 02:09 PM   #4 (permalink)
Tire Geek
CapriRacer's Avatar
On every vehicle sold in the US, there is a sticker - commonly called the placard - that will list the original tire size and the vehicle manufacturer's specified pressure for that size. The placard is usually located on a doorpost or in the glove box, but sometimes it is located in the trunk or on the fuel filler door.
My book does not list a Jeep ZJ, and the listings for Jeep CJ's list quite a lot of different tires sizes as original. What do not want to do is go smaller in load carrying capacity. That increases the risk of a load related tire failure - which sometimes has tragic consequences. So if your placard says the original tire size is a 225/70R15, do not use a 215/70R15.
Not to mention that you'll get better fuel economy with a larger tire.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
Old 10-16-2008, 02:17 PM   #5 (permalink)
according to this Sizes To Fit Your Vehicle
the size you currently have and what size you think was stock, could both be stock sizes.
It's probably a 6 or 7 in wide wheel. If it is a 7 in wide, 215 may be pushing the limit for narrow. If it's 6, you shouldn't have a problem. Any easy way to know how wide the rim is, is to measure from wheel lip to wheel lip, just stick a ruler or tape measure through one of the openings, and get something flat to place across the front and back side to get a some what accurate reading
Randy
Old 10-16-2008, 06:52 PM   #6 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Maybe... Maybe not.
Old 10-17-2008, 12:13 AM   #7 (permalink)
Red
Red's Avatar
They are 15"x7"
You look stock at 235 although 225 sounds familiar
Old 10-17-2008, 07:36 AM   #8 (permalink)
hmm if its 15x7 i should be okay with 215s because the max width for 215s are 7in. and the sumitomos are well over my GVWR. i think my curb weight is mid to high 5000lbs
and these tires are rated 1600s each, which is at least 6400 total. I might shoot for the kumho 215 75 15 since theyre slightly bigger so i wont get such a big speedo error. I wanna switch to something thinner width wise to improve my gas mileage, and more just because i dont need such wide tires, but this also means i will need to replace my full size spare. my jeep is all time all wheel drive.
Old 10-17-2008, 07:36 AM   #9 (permalink)
