Old 02-16-2016, 02:47 PM   #1 (permalink)
Boltar - '19 Chevy Bolt LT
2008 Prius Air Dam
Hey guys, what have you used in the past to create an air dam in the front of the prius? What did you use to attached it to the front. Also I know many have used different methods to create a grill block. What have you found work best? Want to actually start adding some modifications to Padme. Prob going to remove the rear wiper too, it hardly does anything as is.
Old 02-16-2016, 05:05 PM   #2 (permalink)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 26.68 mpg (US)
Can't help you with materials or attachment methods, but it's my understanding that the Gen II should have the upper grill blocked with the lower open because that is where the inverter is located.
The Gen III inverter is located behind the upper grill on the drivers side, so that section should be not be blocked on the Gen III.
I am using pipe insulation to block the lower grill on my Prius (gen III). I've also removed the rear wiper as I don't need to see what is above and behind the vehicle. The lower section of glass is what I actually look through when backing up, and that isn't cleared by the rear wiper.
broski499 (02-18-2016)
Old 02-18-2016, 02:46 AM   #3 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
http://ecomodder.com/forum/497794-post105.html
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 2 Users Say Thank You to Vman455 For This Useful Post:
broski499 (02-18-2016), Daox (02-18-2016)
