Good or bad grill block?
I was wondering about my winter grill block and what you all think about it. Is it hurting my areo or helping it. My temps stay normal in the 173-180 deg f area. Unless it gets over 60 outside. http://i227.photobucket.com/albums/d...psec390822.jpg
http://i227.photobucket.com/albums/d...psduunlwn4.jpg |
Looks good to me.
regards mech |
I don't know about the sides being open if that created bad turbulence. I was wondering if it would be better to block it all the way across or if it gets too hot, to block off the outer parts and leave a hole for the center.
180f? Do cars actually run that cool? Last two I had run at 200f.
Looks good to me, but try blocking all the way across and watch your temps.
Both of my cars run about 185 F, and the motorcycle about 177 F. |
I'm going to try all the way across and see
This is after a 53 mile drive at 65 mphin 17 deg weather. I pulled into the garage and snapped this. http://i227.photobucket.com/albums/d...pshfdtgh5n.jpg Rock auto shows a 180deg thermastat for the 12 mazda 3 2.0 skyactiv manual. My wife's jeep runs above 200 |
Temps look normal to me considering your level of grill blocking, the cold weather, and assuming efficient driving techniques. The fact that you are 8 degrees below the rated temp tells me you can block even more. Try blocking the entire lower grill.
I can get away with about 90% grill blocking on my vehicles during our more moderate winters. |
Can't hurt. Block the brake vents too unless you're crazy hard on 'em.
