EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Good looking back ends????? (https://ecomodder.com/forum/showthread.php/good-looking-back-ends-19939.html)
drmiller100 12-31-2011 08:03 PM
Of cars that is......
I'm designing a NARROW car.
3 feet tall. single tire in the rear.
I can easily run a 20 degree angle on each side, and get down to a knife edge, which is the ultimate in aero, but looks goofy.
Or, I can leave it "wide" and have a 10 inch wide flat back complete with overhang and make it look like a Prius.
Must mount motorcycle license plate, brake lights and turn signal lights.
What looks good? Suggestions? Stuff I can steal or copy?
Frank Lee 12-31-2011 08:05 PM
3' tall? :eek:
drmiller100 12-31-2011 08:09 PM
top of the car will be 42 to 44, depending.
but from the top it slopes down a bit as it heads back, so yes, 36 inches at the back.
why?
Frank Lee 12-31-2011 08:15 PM
I was thinking it might be tough to the get ergos you seek in a 36" tall vehicle.
winkosmosis 01-01-2012 04:27 AM
Make a narrow version of the Oldsmobile Aurora
http://www.carid.com/images/spoilers/SPL/SPL-30565.jpg
winkosmosis 01-01-2012 04:29 AM
Or how about the 300zx? Simple ovals mounted behind a flat sheet of Lexan and you've got it.
http://image.modified.com/f/17369746...+rear_view.jpg
Arragonis 01-01-2012 11:24 AM
How about the Voisin, as I'm reading about just now
http://www.motorsnaps.com/d/22136-4/...+2-litre+1.jpg
Rear wheelbase was originally 1/2 that of the front but it tipped over so they widened it.
drmiller100 01-01-2012 11:59 AM
great ideas. very simple, yet looks good!
Others?
botsapper 01-01-2012 12:57 PM
Not technically a three-TIRED vehicle but actually still three-WHEELED! In the same vein of a narrowed rear track for aero advantages. T3 Motion Inc
aerohead 01-03-2012 05:59 PM
overhead look
Do you have a plan view of your design? You can have as much as 22-degrees taper,but it's very important how you transition into it.
drmiller100 01-03-2012 08:53 PM
I am going to post some pics tonight of the frame. You can get an idea of the overall plan.
