good vacuum pumps?
I need to buy a hand-held vacuum pump ASAP for some diagnostic work on my MAP sensor to resolve ongoing running problems. What do you own? What would you recommend?
1 Attachment(s)
http://ecomodder.com/forum/attachmen...1&d=1322805607
Maybe you have something lying around that can be repurposed. (The amount of vacuum can be approximated from piston position) |
I have a hand pump mityvac, works great for bleeding brakes, and testing whatever. It'll pressurize or draw a vacuum and has a gauge that goes both ways.
