Old 02-01-2011, 02:51 PM   #1 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Steel nanotechnology can reduce the weight of our cars
This seems fascinating -
Steel nanotechnology can reduce the weight of our cars — Autoblog
The world's largest steel maker, ArcelorMital, says it has come up with a new kind of steel that the world has never seen before. Thanks to nanotechnology, the company says automakers can now match the weight of aluminum cars, but do it in steel at far lower cost.
The nano steel itself is not inherently lighter, but it's so strong that automakers can use thinner gauges and that's where part of the weight savings comes from. Another part of the weight savings comes from not having to use additional brackets, gussets or panels to strengthen the structure.
The Following User Says Thank You to t vago For This Useful Post:
menaus2 (02-01-2011)
Old 02-01-2011, 03:10 PM   #2 (permalink)
...beats walking...
...having "lighter-weight" drivers and passengers would ALSO help (wink,wink)!
...you don't need as much "restraint" to hold a 150-170 pound 'object' as you do for a 200-300 pound 'object'.
Old 02-01-2011, 05:14 PM   #3 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
188 lbs from an empty car shell, that's a serious weight reduction !
