Graphene in the News again, with diamonds
i have got to get me sum-a-dat, now!
A bit of similar news.
https://www.fraunhofer.de/en/press/m...save-fuel.html
This firm seems to be working with BMW to deliver diamond coatings on a production scale. All this will result in a few percent more power to the wheels instead of being lost in internal engine friction. |
That's interesting.
You know what else you can make out of tetrahedrons? Bucky Fuller's Vector Equilibrium. Out of that you can make mountains and palaces on a nano scale. Or a flat plane. Or a cylinder that is circular down to atomic scale. Out of plasma. To paraphrase Dick Tracy, 'Whoever controls plasma controls the universe.' They're starting with piston rings and pins. There's also this: Spacecraft built from graphene could run on nothing but sunlight - space - 28 May 2015 - New Scientist In addition to the solar sail now currently on orbit, research shows that graphene sheds electrons when hit by sunlight, producing a thrust increase over other sail materials. |
