Greetings from Washington, D.C.
I've been a long time lurker but I figure I should start participating.
I'm currently building my Civic project car with the following: * D16Z6 block overbored +1mm (from a 1992-1995 Civic EX/Si for non-Honda folks) * 9:1 pistons * D15B8 8-valve head (from 1992-1995 Civic CX) * T28 turbo, planning on running 5-7 PSI of boost * CX/VX transmission Feel free to give me grief. I probably deserve it :turtle: |
Well, at least you've got the idea right about going with the taller geared transmission. Adding a turbo for economy makes sense if you gear it up.
Welcome to the forum. |
With the low compression it'll run decent at cruising but it's going to be very slow getting up to speed = more throttle = more fuel consumption.
I'm hoping that with the turbo assist it can get up to speed more quickly and use less gas. Then it can cruise out of boost. |
