Old 10-07-2014, 07:41 AM   #1 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
Easiest headlight restoration ever!
So I heard about this trick yesterday, and had to try it on my daughter's car
Tools required for headlight restoration:
#1 - soft cloth or paper towel (I used paper towel)
#2 - can of Deep Woods Off insect repellent
#3 - Windex
Steps to restore hazed headlight:
#1 - spray some bug spray on a paper towel, enough to saturate it a bit
#2 - wipe it *briskly* on the headlight, rubbing it in pretty good
#3 - *quickly* wipe clean, don't let the bug spray stay on the headlight for a long time, or it can melt the plastic!
#4 - spray it with Windex and wipe down with a clean paper towel to remove residual bug spray
Don't know how long the results last, but it took less than a minute per headlight, and you can see the difference it made! It actually took off the layer of haze, the paper towel was brown.
ID:	16029   Click image for larger version
The Following 5 Users Say Thank You to cowmeat For This Useful Post:
Fat Charlie (08-31-2015), fusion210 (10-08-2014), MetroMPG (10-07-2014), redpoint5 (10-07-2014), Xist (07-13-2017)
Old 10-07-2014, 08:17 AM   #2 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
Cool trick. I'm going to have to try this. I hate my headlights they are actually dangerous because they are all fogged up.
Old 10-07-2014, 09:03 AM   #3 (permalink)
cowmeat's Avatar
Maverick Hybrids
The "before" pic didn't do it justice, hers were so hazed they were dangerous, too! I feel a lot better about her driving it now
Old 10-07-2014, 09:20 AM   #4 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Fingernail polish remover does the same thing, melts off the oxidation.
Old 10-07-2014, 11:51 AM   #5 (permalink)
cowmeat's Avatar
Maverick Hybrids
Make sure if you guys try this that you spray it on the rag, wipe it on the headlight, rub it off real good and shine it with Windex or something to take all the remaining bug spray off.
There's a youtube video where the guy warns that it could eat right through the plastic! But the headlights I did look real good, and I'm going to wax them tonight just to keep them clear for a while
Old 10-07-2014, 12:27 PM   #6 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Maybe you should add this to your first post.
The Following User Says Thank You to nemo For This Useful Post:
slime (02-06-2016)
Old 10-07-2014, 12:28 PM   #7 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Cowmeat - don't forget about this thread... keep us posted on how long it lasts.
I did it the hard way yesterday: buffer, rubbing & polishing compounds, then wax.
Old 10-07-2014, 01:15 PM   #8 (permalink)
cowmeat's Avatar
Maverick Hybrids
Updated the first post!
Will do!
I'm going to give Turtle's headlights a shot of it tonight, but I'm going to add the step of waxing them afterwards to see if that lasts longer. Maybe I ought to wax one and clear-coat the other to see which lasts longer?
I still have almost a full can of cleat coat left from doing the rim this weekend
Old 10-07-2014, 01:45 PM   #9 (permalink)
90 day: 29.44 mpg (US)
That was how I did it, it did not seem difficult, but I was already polishing my hood.
Old 10-07-2014, 05:33 PM   #10 (permalink)
5 pin sensor
Zippy - '96 Honda Civic Hx
90 day: 40.77 mpg (US)
Boring - '11 Ford Fusion Sel
90 day: 21.88 mpg (US)
Same here, the bug spray way looks pretty easy though I'd like to try it next time. If the windex leaves the surface feeling smooth I would cover it with a wax, if not you could probably make it look new hitting it with a polish then wax after
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
