Grill Block
On a grill block, does the block have to be in front of the grill or could it be recessed (hidden) behind the actual grill?
Ideally...it should be flush on the front but fer "asthetics" you can put it on the back. ;)
If you want a 'stealth' grille block, you can place it directly behind ( flush with the back ) of the grille slats and paint it flat black.
Some grilles come blocked from the factory this way, and no one even notices. For example, look closely at the grille on the Mazda 3 - a large portion is plugged : http://www.fastmotoring.com/oldfiles...ive_la_opt.jpg |
The farther that the block is from the actual grille, the more of an air pocket that is created. Placing the block at the radiator will help, but not as much as just behind the slats like in the picture above.
On another thread I stated where after driving in the rain, I looked at the dry rain marks and the side areas seem to show the most pressure so I think I might do one flush but block it from the sides. |
Made my first template for the block, now I need a clear material that is bendable but pretty rigid and a good way to install the blocks, IE aesthetics in mind.
see link in my signature box |
If it does not matter, the behind the grill would be nice and stealthy. Making a grooved holder for different plates would be very easy. So is it the removal of air from getting in the engine bay, or the actual streamlining of the exterior, or is there a real difference in effectiveness between the two? |
The lower grill block is behind the lower grille and is invisible, permanently mounted, painted black. The upper grille block is also painted black and is attached externally by two long screws through the grille. It is only attached in winter as it would be too restrictive for summer temps. Grille blocks will help the car warm up a bit faster. However, aerodynamically it had no effect on the car's FE, nor did the front belly pan I made. |
front bellypan did nothing? thats sad
