Grill block affected milleage
Trying to figure out what happened, my mileage was worse with my grill blocked anyone have any idea's, this car rolls almost forever so its not mech. All highway(80) 400 miles rolling hills hardly any wind... my only idea is more air is pushed around the side of the car producing a biger wake---Also I found if I remove my passanger mirror there is a lot more wind noise
1986 Saab 900 with SPG aero package lowers CD down to .38 from .42 Running a grill block, a large flat skid plate (for rocks and smooth air) and a large whale tail( it changes rear angle from 25 degrees to 16 degrees) |
- possibly faulty "test" methodology (what are you comparing it to? Identical speed & route? Identical weather & traffic conditions?) - blocked too much, so your electric fan was running a lot more (significant electrical load) - blocked too much, IAT's were elevated enough to cause timing to back down and lost efficiency Quote:
Some people will refer to a mythical Chevy Caprice which supposedly had a better Cd with the mirrors ON, but I'm doubtful that any car wouldn't benefit from a passenger mirror delete. |
Somebody partially syphoned your tank?
Heck could be more cumulative headwinds throughout the tank. |
maybe it has to do with where the engine air pickup is. on some cars the engine picks up it's air in front of the radiator, in some older car from inside the engine bay, but in both cases blocking the grill will cause warmer air to be ingested by the engine, and also a decrease in pressure might cause the engine to have to work harder to breath enough air.
in some cases warm air is a good thing for economy but it also leads to a decrease in performance wich could work out negative for FE since the grillblock seems to work for aero you might considder rerouting your air pickup point to an area where there's higher pressure (the front of the car,) or maybe alter the grillblock so a little opening is situated in fort on the air intake so it car breath unrestricted. |
I had something similar happen my cee'd recently. I blocked the upper grille and the mpg suffered. Its a turbo intercooled diesel so the extra intake heat may have something to do with it. The intake is just behind the grille but at the top of the radiator, drawing air from in front of it. I left the grille block in place and inserted a cardboard radiator block to get the engine hotter. The mpg improved as i reckon the air pressure went up in that area, forcing air into the intake.
By the way, i'm still not getting the mpg i expected. Bleedin diesels! Bleedin warranty too; i cant do bugger all ecomodding to it! ollie |
Hello,
Can you post pictures, please? It's hard to speculate based on a description -- and what were the MPG figures you got before and after? |
2 Attachment(s)
Here is a copy of a post I made on a diesel forum I belong to: So vtec-e, if you increased your diesel's air intake temperature by 19F (~10C) you will have lost about 3.2% of your available power. That will have lowered your mileage since you would have compensated by increased throttle. What is really interesting is that in stop and go traffic my engine compartment air is 48F hotter than outside air! That would cost me a whopping 8% in power, and a corresponding loss in fuel economy. Note that this direct application of Boyle's Law v. power only applies to diesels and not to gas engines which have a much more complex response to air inlet temperature. |
It may not be the grill block its self but where you blocked the grill.
I blocked the passenger side of my upper grill. What I got was cooling problems and I looking at it and said WTF. I only blocked 25% of the total area for air intake. So I changed it to the upper half of the grill still only 25% block and the cooling problem was corrected. Also although I'm not positive but pretty confident that blocking the upper half did improve my fuel mileage over the side block. |
I have only diesels and I have just blocked the lower grill of my car. From the dash board the temperature is greater, but lower than when I'm at highway speeds. I don't have any instrumentation :( so I'll take your informations into account when I have the results for my current tank. Denis. |
Does this meant hat a turbo adds a HUGE advantage in FE to a deisel? 14psi means double the o2 in the air (not quite, due to compression heating, i suppose, but close).
A turbo will needs additional cooling wich will cause additional drag, But a well set up turbo could delever superior FE. there is a curent trent among carmakers to make small turbochared engines to replace powerful big blocks, as these engines have the same power but much better FE and despite the addition of the turbo often weight less, than a big block.
Fiat is working on a turbocharged 2cylinder wich could deliver over 100Hp |
makes sense... you idle like a 70hp p.o.s. and you WOT like a 140hp sport compact.
Could you have a reasonably quiet 2cyl >100hp? That seems like quite a feat. |
just found the picture again with some details
http://i77.photobucket.com/albums/j5...eecilinder.jpg hp ratings don't really tell much (how often do you drive a car near the redline?) so it's where it gots the most torque will matter. Quote:
doesn't look like something that was designed with the mechanic in mind though |
Hi,
A 900cc twin would be a good engine -- if it has a long-ish stroke, it could be quite "torquey". The old "airhead" BMW engine worked very nicely in the 800-900cc displacment, and the torque output was very good. With variable valve timing and a (mild?) turbo, it could be pretty sweet. You also get less internal friction, etc. |
Turbos on diesels do improve fuel economy. Here's why: We've all seen old diesels pouring black smoke from their exhausts. That smoke is unburned fuel because a non-turbocharged diesel simply can't get enough O2 when it is under load. Turbocharging the exact same engine will supply enough O2 to completely burn the fuel, improving FE. However, a diesel not under heavy load will not have its FE improved by a turbo. Turbos on diesels work differently than on gas engines. Diesel turbos only supply compressed air to the cylinders, while gas turbos supply a compressed air/fuel mixture to the cylinders. That's why diesel turbos can increase FE while gas turbos almost always decrease FE. Gas-engine turbos always put more fuel into the cylinders under boost, while diesel turbos do not (but they allow more fuel to burn more efficiently under load). I'm not convinced by the claims of automakers of new turbocharged gas engines that increase FE. I suspect the increased FE comes from use of a smaller engine rather than from the turbos per se. AH! as I was writing this I see that lunarhighway posted something that supports this thinking... a 0.9L turbo engine replacing a 1.2L NA engine. |
Hmmm,
With direct fuel injection, then a turbo on a gasoline engine just compresses air. Do turbo diesels use ever use an intercooler? (If the main purpose of increasing compression on a diesel is to heat things up...) On a turbo gasoline engine, an intercooler can improve power (and probably boost FE) by increasing compression but avoiding pre-detonation because the heating (from compression) is reduced? |
http://ecomodder.com/forum/15012-post5.html |
mileage down
But you are right, my post was worded badly. When I re-read it I see I gave the impression that no NA engine at full throttle ever got enough O2 and that all NA diesels belched black smoke - neither of which is correct. In fact, I have a 95 NA diesel that doesn't visibly smoke under full throttle. However, having said that, all diesels smoke under load. It just isn't easily seen in daylight with the naked eye. |
grill block restricts engine ecu?
hi
so i installed a grill block but i didn't get the mpg hit i was expecting. i noticed the fan kicking in a few times but mostly i couldn't hear it above the engine noise so i don't know how much? the temp gauge seemed fine, above normal but in the middle of the gauge, 105*C. i also noticed that the car seemed very restricted, top speed reduced, yellow "no spark" warning light came on one time i tried to overtake. was the ECU restricting the engine to stop it from overheating? and if so what effect would this have on FE? |
Hi modmonster - hope you don't mind I merged your post into this thread which deals with the same types of questions you're asking.
I'd say that 105C is too hot (that's 221 F - my car's cooling fan comes on @ about 205 F). You need some way to monitor your temperature more accurately, or add an LED light so you know if your cooling fan is coming on. You may have overblocked things. |
it wasn't in the red part of the dial so i just kept driving Lol
whats the best way to grill block? my car has two grills -a fake asthetic top grill where the badge is, and a real opening lower grill.
i have taped up the fake top one and (now) 3/4 covered the lower grill. -was completely blocked for the last test just to give a base point. |
Copyright ©2000 - 2021, vBulletin Solutions Inc.
