EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Grill block mounting help (https://ecomodder.com/forum/showthread.php/grill-block-mounting-help-23783.html)
c4a8l 10-25-2012 06:51 AM
Im looking to make a set of brill Blocks for my VW Passat and im making them out of clear Perspex so they are as clean and stealthy as i can get it as i want to have a factory fitted look but my problem is how can i mount them with out having bolts or cable ties showing?
im looking to do all 3 Lower grills with a vent in the center grill.
Also a Half block on the Large center Grill with the VW Logo.
I want it to look a clean as possible.
Thanks
Carl
AndrzejM 10-25-2012 07:47 AM
1 Attachment(s)
Maybe you could cut grill block with some additional mounting points, heat them up and bend to the inside, then use zip ties or screws to mount it?
http://ecomodder.com/forum/attachmen...1&d=1351165660
c4a8l 10-25-2012 08:45 AM
I did think about that but there isnt enought clearance between the bumper and the grill.
AndrzejM 10-25-2012 08:55 AM
Can you take a pic of the actual front of your car? That will be easier to see what we're talking about.
c4a8l 10-25-2012 09:24 AM
Yes i will get one up in a bit.
c4a8l 10-25-2012 09:26 AM
http://i136.photobucket.com/albums/q...8l/passat7.jpg
The grills are a tight fit in the resess of the bumper the upper grill should not be a problem its just the lowwer grills.
AndrzejM 10-25-2012 09:31 AM
Why you don't want to use those holes in a "black" area? The actual grill...
c4a8l 10-25-2012 09:35 AM
The two side grills are only half open and dont fancy having visable cuts in them.
AndrzejM 10-25-2012 09:55 AM
1 Attachment(s)
Maybe some thin pieces of inox, screwed to the Prespex and fitted into the tight space between grill and bumper cover?
http://ecomodder.com/forum/attachmen...1&d=1351173246
euromodder 10-25-2012 10:53 AM
You could put the grille block on the inside, for that stealthy look.
c4a8l 10-26-2012 06:13 AM
I will have a play with it at the weekend and let you know how i get on.
Arragonis 10-26-2012 12:35 PM
Cheap and simple option - Black correx (coropast here in the UK) - A3 sheets are on ebay for a few pounds. Then cable ties - the long ones or double them up and wrap them inside the grill, maybe 2 or 3 on each side.
That way you can experiment and remove (servicing - dealers don't like them) or adjust them easily (scissors).
If you get them in black then won't show up at all too.
Did this with my Fabia and it lasted a whole winter (snow included) in one piece. My Aygo has the upper nostrils and 85% of my lower grill blocked this way too.
mcrews 10-26-2012 06:32 PM
See the grill block link in my signature.
c4a8l 10-27-2012 03:47 PM
Well i got a sheet of 2mm Clear perspex and cut all 4 grills out to fit and im really happy with the 3 lower grill's you can hardly tell they are there at all and they look Factory fit which i what i was going for but the main grill i may have to look at again as im not 100% happy with that yet.
I ended up using black foam number plate sticky pads to fix the grill blocks.
I will get some photos up tomorrow for you to have a look at and make any suggestions.
I may end up getting a De-badged front grill so i can make a cleaner block.
c4a8l 10-28-2012 05:02 AM
All 4 grills blocked
http://i136.photobucket.com/albums/q...l/SNV30774.jpg
http://i136.photobucket.com/albums/q...l/SNV30773.jpg
http://i136.photobucket.com/albums/q...l/SNV30772.jpg
http://i136.photobucket.com/albums/q...l/SNV30771.jpg
http://i136.photobucket.com/albums/q...l/SNV30770.jpg
http://i136.photobucket.com/albums/q...l/SNV30769.jpg
Im going to change the main grill block once iv got a de-badges grill.
Arragonis 10-28-2012 05:11 AM
looks very neat
Otto 10-28-2012 10:13 AM
Nice touch.
AndrzejM 10-29-2012 04:17 AM
Nice!
