Grochu modding thread - eco gasser (image heavy)
12 Attachment(s)
Hi Guys,
This is my new thread about modding my Polo 1.4 I've worked on it recently and the plan was to install MPGuino and kill/start switch. Here are the results. First thing was to tear apart the dash to get access to the electric harness. http://ecomodder.com/forum/attachmen...1&d=1423427942 Then I've installed some cables for MPGuino feed and the kill switch. Injector signal cable http://ecomodder.com/forum/attachmen...1&d=1423428341 Kill switch relay - it's cutting hall sensor signal http://ecomodder.com/forum/attachmen...1&d=1423428341 Since my gear shift knob was made of aluminum it was almost impossible to cut the hole for the kill switch. I wanted to put it the same way as I've made it in Berta I needed to fabricate a new knob. I used a piece of oak wood (that is over 80 years old!) Fabrication process: http://ecomodder.com/forum/attachmen...1&d=1423428965 http://ecomodder.com/forum/attachmen...1&d=1423428965 http://ecomodder.com/forum/attachmen...1&d=1423428965 Kill/Start switch and the knob finished http://ecomodder.com/forum/attachmen...1&d=1423428965 Finally I was able to install MPGuino: http://ecomodder.com/forum/attachmen...1&d=1423429452 http://ecomodder.com/forum/attachmen...1&d=1423429452 If you wonder where is my radio :) http://ecomodder.com/forum/attachmen...1&d=1423429612 On the outside of the car first thing I just needed to do was to limit the air going through the engine bay: Just a duct tape, some pipe insulation and stainless steel wire mesh http://ecomodder.com/forum/attachmen...1&d=1423429769 http://ecomodder.com/forum/attachmen...1&d=1423430184 That's all for now. More to come soon (hopefully) Now I need to calibrate MPGuino :) |
Nice work on the shifter knob and kill switch. :thumbup: > |
2 Attachment(s)
Kill switch details:
http://ecomodder.com/forum/attachmen...1&d=1423485066 I just cut in the signal wire between the hall sensor and ECU. Relay is controlled by the switch on the gear shift knob. Start switch details: http://ecomodder.com/forum/attachmen...1&d=1423485467 Start switch on the knob controls the relay that is connecting wires that are going from the ignition switch. |
Awesome build so far! I, too, love the shift knob.
Keep us posted! |
Nice job on the wiring and shift knob! I really like the VW Lupo and Polo models. Since your previous builds were really well done, I'm sure this one will be great too!
First ride behind me. MPGuino needs calibration - definitely, because readings are way off. All other things works flawlessly. Kill switch and start switch works just great, but knob needs some work though... It's a bit to big and I want it to fit my hand as it should. :)
Thanks for the kind words. :thumbup: |
3 Attachment(s)
On last Monday I got info, that i need to go to Prague. My car was still in pieces, so on Monday evening I needed to put it back together and make some changes I've planned.
Anyway I've managed to fix everything inside the car and to work a bit on the front. Duct tape comes in handy, as always. Upper grill block: http://ecomodder.com/forum/attachmen...1&d=1425899970 And then I've managed to make an air dam. I had a rear bumper cover from Opel Corsa, that I got from a local junkyard. http://ecomodder.com/forum/attachmen...1&d=1425900451 I cut it in half, frlipped over and voila, an air dam :) http://ecomodder.com/forum/attachmen...1&d=1425900399 I've used lots of rivets, some stainless steel mesh I know it looks like a bodywork by Freddy Krueger, but it works pretty well. On my way to Prague and back I've managed to squeeze out 1129km from relatively small tank with an average FE of 3.83 l/100km (61.41 mpg US) Not bad IMHO :) More changes to come... |
