Guesses on Cd?
The Nissan Titan "Triple Nickel" land speed racer, unveiled today at SEMA:
http://duaj5928mzrrb.cloudfront.net/...42-768x432.jpg Lowered, salt-scraping air dam, solid wheel covers, and looks like a full bed cover. http://duaj5928mzrrb.cloudfront.net/...82-768x432.jpg http://duaj5928mzrrb.cloudfront.net/...46-768x432.jpg |
The extended cab with wind tunnel tested roof arc might make the need for a roof wing or aero-shell less critical. However, they seem to be missing out on a lot by preserving the typical pick-up truck looks.
A Practical Guide to Pickup Truck Aero-mods https://i.kinja-img.com/gawker-media...vzhmuu6xes.jpg To make an accurate guess, look at another similar truck. I could not find a Cd number for the two examples I looked into. I mean they didn't even do a grille block and side skirts like this Ford below. http://www.trucktrend.com/cool-truck...f250-scorpion/ http://image.trucktrend.com/f/346142...ind_tunnel.jpg Quote:
I'd have to double check my rulebook, but IIRC, /DT largely follows the rules for the /GC (Gas Coupe) category. /GC is not allowed any streamlining other than removal of mirrors and trim, lowering, air dam, and wheel covers. I think /DT specifically allows tonneau covers. It looks like Nissan has done all that and stopped there. I am a little surprised that there is so much wheel gap up front and the windows are rather unusual, but otherwise it looks clean. My official guess: Cd = .300 |
I'm guessing the truck is in the current form for the show, and will be modified further for an actual attempt per the quote "additional safety equipment and more – will be added within the next few months as the truck is developed with an eye toward setting new class speed records."
Several other little do-dads are already made but removed for the presentation. Gotta glitz it up for press! |
I'm going with .27 - I would have gone lower, but Kach pointed out the open grille.
As far as the open wheel wells, and lack of side skirts, I keep thinking back to the HotRod 1980 Camaro, which achieved a verified .201 Cd with nothing more than an airdam, a plugged grille and headlight assembly, a simple shelf spoiler, lowering, and moon disks. No side skirts, no belly pan ( later added, but not present early on when tested ) etc. ( And that .201 figure is with the giant scoop on the hood ! Amazing. http://image.motortrend.com/f/593306...Bonneville.jpg |
That Camaro test also demonstrates how much of an impact seemingly-minor details can have. Raising the rear by 1.5" increased Cd to .227. They also tested three different hood scoops, with the final version same Cd as no scoop.
From the original article: Quote:
FIA World Land Speed Records | Federation Internationale de l'Automobile Quote:
Interesting--class A-III-9 is FIA, and breaks down to Automobiles (A--as distinct from "Series Automobiles B"), diesel engine with supercharger (III), 3.0-4.0L displacement (9)--but the Titan has a 5.0L engine. Nissan isn't telling all in that press release, apparently.
D/DT looks like an SCTA diesel pickup class that doesn't allow changes to bodywork. That's probably what we're seeing in these photos. |
Then suddenly, a butterfly crosses the road, instantly sending your Cd number skyrocketing to .30 :D |
So what is the official Cd quoted at ?
changes
You can: *block the grille *lower it so much *yank the wipers *yank the mirrors *add MOONs *add stabilizing air dams, spoilers,fences *HOT ROD's Camaro got to use a bellypan ------------------------------------------------------------------------- Otherwise,it better be 'stock' |
Sorry I didn't get any pics for you guys, I was there Tuesday and the cover was still on it.
There was also a 4 cylinder Cummings in the booth, I assumed it was for a future small truck, but it may have been in the land speed Titan.
The Fusion is an oddball, because there is no class for "production-based fuel cell car". This was either run as a time-only car or as an Electric (/E) which is Special Construction (basically, anything goes as far as aero is concerned). I don't know what VW Jetta you are referring to. There are three diesel truck categories, Diesel Truck (/DT), Modified Diesel Truck (/MDT), and Unlimited Diesel Truck (/UDT). /DT is intended to represent a typical diesel pickup truck with all panels in their stock positions and almost no streamlining (mostly following the rules of the Gas Coupe category /GC). Both the Nissan and Ford above appear to be /DTs Grill blocks are specifically barred. Belly pans are specifically barred. A flush tonneau cover is allowed, but no other streamlining behind the cab is allowed, no spoiler. An air dam is allowed, but the bumper must remain stock and it may not block the grill. Mirrors may be removed, but door handles and window trim must remain stock. Hot Rod's Camaro raced in a variety of categories, typically as a Classic Altered or Competition Coupe. Altered allows significantly more streamlining, including a "Step Pan", CC goes even further. Classic is for cars 1949-1981, their Camaro is a 1981. |
Jetta
Here's B/DT pickup which ran in 2014.It looks like a 'fit' to the rulebook http://i1271.photobucket.com/albums/...2/HPIM1921.jpg When I ran in 2012,it was just for time and I could do whatever I wanted to the truck. http://i1271.photobucket.com/albums/...HPIM1874-1.jpg Ford with illegal grilleblock http://i1271.photobucket.com/albums/...titled4_12.jpg Very illegal Impact/EV1 http://i1271.photobucket.com/albums/...titled3_14.jpg HOT ROD's looks illegal http://i1271.photobucket.com/albums/...ntitled316.jpg |
This is the Jetta, when it was at the LeMay museum (might still be there, I haven't been in a couple years):
http://i1047.photobucket.com/albums/...ps2717886d.jpg |
Streamlining rules vary a lot by class. |
As a /PS, streamlining is limited. |
Jetta Hybrid LSR
I found the Motor Trend article.
*mirror delete *wiper delete *lowered *MOONs *air fences on roof for safety *narrow,and near bald GoodYear EAGLE racing tires *MT thought Cd would remain the same @ Cd 0.28 (I'd guess around Cd 0.263 because of the mirror delete) *MT says frontal area went from 20.7 sq-ft,to 19.6 sq-ft *Jetta averaged 186 mph and change *single highest 1-way pass= 187+ mph. *MT doesn't say if 300-bhp,1.4-liter was measured at near sea level in Southern California,but I suspect that this is the case.If so,the bhp on the salt could be as low as only 86% of rated power due to Bonneville's density altitude.(Re: Rick Gold,CRC Racing Fuels,meteorological reports). *the 27-hp electric motor (supercharger) wouldn't experience a change of course. |
So has anyone come across the official Cd ? ( of the Titan )
official
Considering the 1989 GMC Sonoma LSR with Cd 0.315,and the current Cd 0.36 RAM 1500 Regular Cab with grille shutters/ active suspension/toneau cover,it seems reasonable that the Titan will be in between,maybe Cd 0.337? |
pickups: Cd 0.315-0.309
Here is the Cd 0.315 1990 GMC Sonoma,and current Cd 0.309 Holden VR Commodore Ute
http://i1271.photobucket.com/albums/...titled28_6.jpg http://i1271.photobucket.com/albums/...titled27_9.jpg http://i1271.photobucket.com/albums/...titled26_9.jpg |
