IT guy with an Accent
Just bought a 2002 Hyundai Accent L
1.5L SOHC with 82K on it mated to a 5 Speed Manual. Coming from a 01 Jeep Wrangler with a 4.0L Inline 6 should be interesting to say the least. Plans so far: Go to max sidewall Make repairs as I find them (this isn't a spring chicken) Hot air intake (possibly a selectable hot/cold intake) ScanGauge Assorted manual gauges (this thing has no TACH... I hate when they do that!) Possibly something with the gearing (this has to be turning to many RPM's at highway speed) Image although I cannot post them yet. "im1.shutterfly.com/media/47a1ce30b3127ccefe022511fc7500000010O02AcM2bhizatA e3nwE/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/" |
Hmm...the Accent had the 'Alpha' engine compared to my Elantra's 'Beta' series. I know from experience that the Betas do NOT like hot intake. Anything over 110* F and it bogs in comparison to lower temps. Best range for me is 55-100* F.
I don't know if you'll find the same thing or not. You might (depending on your area) be able to find a gauge cluster from a different trim that has a tach and swap them. What manufacturer/make are the tires currently on it? |
Rick |
Likely the tach will come first... Buying this car killed my savings and I will have to build back up. |
Tires are nasty huge luggy snow tires. I was also given another set of All seasons but I haven't had time to think about them yet. Got the car registered today.
I bought the car because I wanted something fun that would still get good gas mileage after my wife realized that she was working just so we could afford the Jeep. Also my Jeep grenaded a piston so now I have to fix it. |
Start by pressing up the tires to 40 PSI or so - that's probably the easiest/cheapest/fasted mod. If you can get some sort of upper grille block on it, that'll REALLY help the warmup part. Depending on your commute, that could net you 2-3 MPG.
Be careful when you change oil on it! My 2.0L Elantra (2004) only takes 3.5 qts. I think the little Accent engine is only 3.25 - check the manual for sure. Shift low, and get to 5th fast. Optimal acceleration *probably* starts around 2000 RPM. I'd shift no later than 2750 max; 2500 may be even better. Cruising RPM in the 1500-2000 range should help you keep the MPG up. PANTS! You don't have a tach. RRRRRR... 1-2 shift at 8-10 mph 2-3 shift at 14-18 3-4 shift at 22-26 4-5 shift at 28-32 Those are rough guesses, but should be within 1-2 mph. I'm pretty sure you should be able to do 30-35 mph in 5th without lugging. It's near the bottom of the gear, for sure - probably 1200-1400 RPM. Alignment may be a good idea - the default specs are almost zero on 'em. Check out Hyundai Service Website - it's practically the full shop manual for the car for free, from the manufacturer. PM me some time and I'll walk you through how to use it (can be a little confusing). Does that have a serpentine belt or a 3-belt setup? If you don't mind Popeye steering, and it's got a 3-belt setup, you can pop off just the power steering belt and leave the others on. :D First pic link wasn't working for me. I'll ask on the Elantra forum (we do all HyunKia, though) about a cluster swap for you. |
Update! The clusters are direct-swappable. Make sure you keep your odo so the mileage is right.
Cluster swap on an 02 Accent? - ElantraClub - For Hyundai Owners and Enthusiasts |
Welcome! Hyundai makes some nice cars, I looked at several as I car hunted.
kage when my buddy bought his 2000 Hyundai Accent I thought it was a piece of junk. But he still has it and I've had 5 cars since then. He's still getting 40mpg in it but he drives like a granny everywhere. Good luck you on your project I'm interested to see your baseline tests vs mods.
