Old 02-11-2009, 04:34 PM   #1 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
Hi everyone
Hi,
I have been driving for 12 years now, all sorts of european cars and I have a thing for modding ...
Be it turbo-ing my Mini, fitting high-comp piston to my supermoto and now making my work commuter less fuel thirsty.
Obviously european and especially french cars are pretty economical but you still get to do a little better than what is there to start with.
So, the car :
2001 Renault Megane DCi
Looks like that but mine is dark grey
It's got a 1.9 diesel turbo common rail engine (105 HP and 20,4 mkg at 1 500 rpm) weigh 1,250 kgs and is said to return :
Highway : 4,4 l / 100 km
mixte : 5,2 l / 100 km
urban : 7,2 l / 100 km
I am having a consistant 5,3 on my commute to work at this time of year and have seen an all time low of 4,8 on a long journey from south but that was using A/C sparingly and driving in the 110 / 120 km/h region
Anyway, I plan to do something for the front lower grille (in the bumper) and add rear wheel fender from an R25 to start with. THere is work to do under the car as well especially on the rear.
I would really like smaller rear view mirrors (they have to be out of the car) and work on the weight of the car.
Seems like a great forum and finally people with which I can share !
Bye
Old 02-11-2009, 04:43 PM   #2 (permalink)
Welcome to EM. I look forward to seeing what you can do with that car.
Do you use a lot of our ecodriving tips already?
Old 02-11-2009, 11:59 PM   #3 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Welcome to EM!
There are 2 things with your vehicle that are advantageous: it's an Estate with a Diesel (both are rare in the US these days). We only have the VW Jetta (Bora) "Wagon" TDI in that range.
Tell us more about your Cooper! ...sounds like fun.
Best FE,
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 02-12-2009, 12:09 AM   #4 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
renault_megane_dci -
Welcome to EM! In California I only require one outside mirror. I used a small bicycle mirror like this :
Originally Posted by cfg83 View Post
Hello -
I am working on a side view mirror downsize. I got this bicycle handlebar mirror from REI :
Blackburn Multi Mirror
Mirror "triangular cover" Gap
CarloSW2
American Solar Energy Society
Old 02-12-2009, 03:03 AM   #5 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Hi renault_megane_dci
It's nice to see that your Megane doesn't have roof railings that a lot of European stationwagons have.
Old 02-14-2009, 02:34 PM   #6 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 renault scenic
90 day: 43.09 mpg (US)
megane - '97 renault megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Toyota Prius
90 day: 69.27 mpg (US)
Hi renault_megane_dci, welcome on board.
I have the scenic version (an MPV version) of the megane with the same engine and from the same year. My scenic is also 105HP but has 20.8 m.kg the weight is 1290 kg and both frontal area and Cd are more important.
My consumptions are 4.9 highway, 7.7 city and 5.9 combined.
As my wife and I are sharing our cars, I don't drive it often. This summer I was under 5.0 l/100 (over 47 mpg) on my daily commute. At Xmas I achieved a 4.41L/100 (53.32mpg).
I did a full front grill block (except in front of the turbo) which works very well to keep the engine hot and we had no overheating problem yet but I'm wondering if for highway it isn't a little bit too closed...
These results were with tires inflated at 3.5 bars (51 psi), a lower steady speed and driving without brakes. In city I'm using pulse and coast in neutral (with engine on). Currently in the megane classic (our older car), I'm using pulse&coast at higher speed and I'm beating my summer results : 4.4L/100 (53 mpg).
Have fun,
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
