Harbor freight engine swap
Not intended to be eco specifically, but I bet it would get great mileage. Of course it doesn't have a clutch or throttle, so they have to push start it. I'm really surprised they didn't rig up a throttle, wouldn't be too hard!
Pretty cool! :) https://www.youtube.com/watch?v=52pL2-NozN4 |
Unless it's fuel injected, I doubt it would get very good gas mileage. Maybe not even then. The BSFC on these engines is about 350 g/kwh; That's in the poor range of a car engine, which will hit about 250 g/kwh in it's sweet spot. No timing advance, no OHC, nada to help it.
There's a similar video with a Geo Metro with a 10hp diesel and a CVT. That might have been limited in speed, but would have been a bit more efficient at least. |
It does have overhead valves(pushrod), so at least its got that going for it. These engines are also built for a much narrower engine RPM range than car engines, so they should run fairly well at those speeds. Lawn engines come with uber soft valve springs, so the valve train friction should be pretty low. I couldn't even check the valve clearances in my honda GCV 160 without the feeler pushing the valve down and giving a false reading.. |
My 20 year old car engine peaks around 210 and is under 250 for a majority of realistic operating conditions.
:turtle: |
Should have had the clutch and throttle hooked up and they could actually drive the thing.
I have already considered to fit a car with a recoil starter similar to that stationary engine, even though I was willing to try it in a conventional car engine. That was an early Pontiac Trans Sport with the 3.1 engine and a TBI, which had a malfunctioning starter and some other electrical failures...
But anyway, back to topic: with a clutch and a properly linked throttle, I wouldn't mind taking a test-drive on that. |
Assuming gas weighs 6.2 lbs per gallon, also assuming their "continuous rated output at 3600 RPM" means maximum power output at 3600 RPM, which was listed. GCV 145 (7.7:1 CR) 263 g/kw/h GCV 170 (8.0:1 CR) 247 g/kw/h GCV 200 (8.0:1 CR) 247 g/kw/h Its too bad the 145 was dumbed down with a lower compression ratio, it is the only undersquare engine of the three. These new engines however are much more undersquare than the engines they are replacing. The engines these are replacing also had higher compression ratios as well: 8.5:1 No promise a chinese clone of older Honda pushrod technology is that efficient, but don't underestimate small engine efficiency. https://global.honda/newsroom/news/2...13eng-gcv.html |
Specifications
MODEL UP190 Engine Type Single-cylinder,4-Stroke,Air-cooled,OHV Gasoline Engine Bore X Strorke/(mm) 90X66 Displacement Capacity/(cc) 420 Max.Output/(HP)/rpm 14/3600 Fuel Consumption/(g/kWh) ≤374 Less than is a start, though not a great one... Brand Honda Power Source Petrol Power Details Air cooled 4-stroke OHV petrol engine, 25° inclined cylinder, horizontal shaft Cylinder Sleeve Type Cast iron cylinder sleeve type Bore x Stroke 82 x 64 mm Compression 8.0 : 1 Max Power Output 8.1 Kw (11 HP) / 3600 rpm Max Torque 23.5 Nm / 2.4 Kgm / 2500 rpm Ignition System Transistorised Starting Method Key Start Fuel tank Capacity 6.5 litres Specific Fuel Cons. 313 g/kW.hr 313 isn't so bad...but none of these compare to what's in your post. |
Go Kart
Have watched youtube…..A couple of thoughts ….
2cycle go cart horizontal shaft harbor freight Chinese knock gas engine will be underpower ...will wait to see how accel and hwy speed workout |
gkart
Oh yeah just because you can do something does not mean you should go ahead and act on that mindset. Common sense is not as common as one would think
Some motorcycle engines with a smaller displacement, despite running at a higher RPM, might actually fare better than those stationary ones. Cross-shifting might not be so appealing, but it would still be better than having no clutch at all...
