Old 08-31-2008, 07:48 AM   #1 (permalink)
oldtech1's Avatar
magnetic engines
i have attempted to make a magnetic engine like those you might have seen
on youtube.ive tried 2 different types
ive had poor results from both thou i see the potential for the application
if they really worked .
for solar charging i have found a alternative to pannels that might get more amps if a alternator and sun trakker is installed.
Old 08-31-2008, 09:55 AM   #2 (permalink)
jeremy128's Avatar
Insert debate about the first law of thermodynamics here.
Old 08-31-2008, 11:35 AM   #3 (permalink)
oldtech1's Avatar
stirling motors already in california power some of there grid
Old 08-31-2008, 12:23 PM   #4 (permalink)
jdub's Avatar
TDI Cup - '10 Volkswagen Jetta TDI Cup Street
90 day: 50.3 mpg (US)
Those are not magnetic engines though
Those are engines that run off a temperature gradient from ambient air and focused solar heat.
The original post is about something totally different than Sterling Engines.
Old 09-01-2008, 12:20 PM   #5 (permalink)
oldtech1's Avatar
you are correct my post is in 2 pieces.
the first 1/2 is about the poor performance of magnetic engines.
the second is on using stirling engines as a alternative to solar pannels to
charge ev's
Old 09-01-2008, 03:12 PM   #6 (permalink)
jdub's Avatar
Sterling engines
charge ev's
I think Sterling engines are pretty sweet in concept and its amazing how old the idea/technology is, however plans for highly efficient and economical version are closely guarded trade secrets and as a result its impossible to find readily available plans for DIYers. you are seeing them in use in more and more products though.
Camshaft timing/tinkering (2001 Civic LX) mechman600 EcoModding Central 28 05-19-2013 04:12 PM
Mid-engine, Rear- engines superior for aero? RiseAbove Aerodynamics 38 10-07-2010 07:42 PM
turbo engines: getting to speed heh2k Hypermiling / EcoDriver's Ed 20 08-09-2008 01:32 PM
P&G for Bicycles? superchow Alternative Transportation 18 07-24-2008 11:27 PM
New here, into GM 2.8/3.1 engines wagonman76 Introductions 7 06-09-2008 02:01 PM
