EcoModder.com
-   -   has anyone built their own cng compressor (https://ecomodder.com/forum/showthread.php/has-anyone-built-their-own-cng-compressor-39895.html)
assistance 01-02-2022 12:28 AM
thinking of buying a $250 dollar scuba compressor (4500psi) on amazon to compress CNG for cars.
The CNG stations charge 1.60 / GGE, and homefill would be 30 cents per GGE.
The plan would be to have a flash back arrester on the intake to the compressor to prevent any accidents from going back into the main line.
Might also have a check valve to make sure the gas only goes one way.
It would appear impossible to have a flashback arrestor on the tank line due to 4500psi.
I havent been able to source cng service nozzles, i found fill ones but not the service handles like at the station, so i will be using a diy connector system that is rated for 4500psi, probably ball valves instead.
What u think of the plan?
teoman 01-02-2022 09:17 AM
Did you calculate how much cng you would need? And how many tanks you need to fill?
I had a look at those 250 compressors, the ones where you also attach a bucket of cold water. they are mainly for filling airgun tanks. So with such high volumes, i do not know how long they would last.
What car do you have?
teoman 01-02-2022 09:18 AM
1m^3 is roughly 1l of liquid fuel.
A 10L scooba tank will hold 2000L at 200 bars. So 2 liters worth of fuel.
MeteorGray 01-02-2022 10:57 AM
I would research the project thoroughly before attempting it. Compressing natural gas sounds like a daunting venture in view of the potential for disaster and liability.
ksa8907 01-02-2022 02:42 PM
At those pressures you would need supercompressibility calculations to more accurately determine how much energy you can put inside your tank.
However, (atmospheric pressure [absolute] + final cng pressure) ÷ (utility base delivery pressure [absolute]) = standard cubic feet per one actual cubic foot.
So a 1 cubic foot tank can store roughly 308 cf at 4500 psig.
I think what you're going to find is that to have a relatively safe and reliable system it will cost more money than it is worth.
Also, what are you going to do with the condensate?
rmay635703 01-02-2022 08:54 PM
If it’s not rated for flammable gases I wouldn’t waste time on it, not worth explosions
ksa8907 01-02-2022 09:52 PM
Things do fail in spectacular ways, luckily though for NG, it's basically inert above 15% concentration in air. If no oxygen is mixed, it's quite safe.
Piotrsko 01-03-2022 08:55 AM
Don't know about your specific community, but in many cities, they inject atmosphere into the natural gas stream in the winter to boost flow and pressure during the winter, typically below 10%. The utilities state this is quite safe and other than loss of range, the 3000 psi CNG bus I drove had no issues.
ksa8907 01-04-2022 07:57 AM
Atmosphere? Like air? I've never heard of that in the industry but propane-air injection is fairly common. Though that is also being displaced by LNG.
Piotrsko 01-04-2022 09:07 AM
Yup: air consisting of whatever is at the input filter of the diesel pump. Have a friend that did maintenance inspections of them yearly all over the country.
ksa8907 01-04-2022 09:43 AM
I've never heard of it and quite honestly, I'm skeptical if it's true. Utilities are required by state commissions to keep BTU content within a specific range, air would obviously reduce that to illegal levels.
Piotrsko 01-05-2022 10:29 AM
Be skeptical all you want, affects reality not at all. The utilities self cert for compliance, who else has the test equipment?
ksa8907 01-05-2022 11:13 AM
I understand your position but being quite familiar with the industry and best practices, I remain skeptical that what you're describing is truly air only.
https://algas-sdi.com/what-is-propan...20applications.
"Propane-air, also called LPG-Air or SNG, is essentially synthetic natural gas that is formed by mixing vaporized propane or LPG with air. Once mixed it forms a homogeneous mixture that can be used as a direct replacement for natural gas in combustion applications."
windshadow 02-28-2022 10:42 PM
Used parts
assistance:
I do related work for a company that makes natural Gas service trucks. They have a considerable amount of old trucks sitting around. They repurpose the tanks to the newer trucks. You could find a manufacturer locally and see if they have the part you need.
Tahoe_Hybrid 03-03-2022 03:08 AM
dude it's going to take a LONG time to fill using a home gas pipe it's better to just use the station they use High pressure gas lines
the house pipe is 10psi that is at the tap
after the meter & regulator it's down to 1psi 7-10 hours fill time... if you had 10 psi at the stove the flame would be 10x bigger
source: talked to the gas man before
ksa8907 03-03-2022 09:49 PM
Lol, I am the gas man.
Residential delivery pressure is generally 0.25psig. 10psig on a house line would blow up the 2# regs that are built into most appliances and any pilot would be extinguished and blowing gas... and then kaboom goes the neighborhood.
If it's a recent gas line installation, it's probably 1/2 mdpe. I don't recall what the maximum throughput is but it would also depend on your distance from the main. In any case, residential meters will not pass more than about 500scfh.
To the OP, again, the cost to make a reliable and safe compressor will not be economically viable.
cRiPpLe_rOoStEr 03-04-2022 12:31 AM
CNG has a much higher pressure than bottled propane, so it makes me less willing to try any makeshift for CNG handling.
