Has anyone moded mkIV Jetta
I'm new to the forum and have been looking through and haven't found if anyone has areomoded a mkIV jetta. All I have done so far is grill covers and that's it and I was wondering what if anything else can be done.
Welcome!
I believe there are several on this forum that have modified their mkiv's, both Jetta and Golf. In my case, I've done the grill block and some under-body coverings: Grill block: https://lh5.googleusercontent.com/-D...520Q1-2014.jpg Front under-body (this is the bottom of the front bumper, which I removed to put the coroplast on): https://lh6.googleusercontent.com/-L...0/P4130013.JPG This combines with an engine skid-plate (mine is an OEM steel version, but there are also aluminum ones as well as the OEM plastic under-engine cover) Rear under-body coverings (closes up the rear bumper "parachute"): https://lh5.googleusercontent.com/-W...-12-53_145.jpg Helga is also lowered by about 1" so that the tires are less exposed. Would be interesting to see your grill covers. |
