Has someone tried base bleed?
Hey guys,
There are a number of intriguing papers about the "base bleed" mod to increase fuel efficiency like : 2012, Optimum Way to Increase the Fuel Efficiency of the Car Using Base Bleed, 2018, Reduction of Aerodynamic Drag Force for Reducing Fuel Consumption in Road Vehicle using Basebleed 2016, DESIGN AND ANALYSIS OF CONVERGENT BASE BLEED IN AUTOMOTIVE STRUCTURE Ever heard of this mod? Anybody did something like that? I want to install a belly pan on my 99 Acura EL (same as Civic Ex sedan in US) and should this mod be worth, it would have to be installed before the undertray. Facts and opinions will all be welcomed. Acel |
If you can get a belly pan for a 20 year old car definitely go for it.
Automotive base bleed a.k.a. running a duct(s) from a higher pressure area to the back to "fill" the trailing wake. It has been discussed. IMHO if you have the excess space in the vehicle envelope for ducts, you could chop the top and do even better because ducts have their own drag. But what do I know; I haven't tested it and aero ducts in other places are enjoying some popularity.
Aston Martin did something similar with their Aeroblade on the DB11, but that's an aerodynamic spoiler--the duct outlet is sited at the base of the rear window and exhausts normal to the surface. I don't know where the intakes are. https://s1.cdn.autoevolution.com/ima...de-works_2.jpg https://cimg3.ibsrv.net/ibimg/hgm/19..._100558507.jpg |
base bleed
aerohead is usually right. That said, my favorite examples:
https://ecomodder.com/forum/member-f...w12-650-16.jpg Golf GTI W12-650 https://upload.wikimedia.org/wikiped...6082370%29.jpg https://en.wikipedia.org/wiki/Ford_GT The ducting needs to be generously sized. Dryer vent ducting won't cut it. Close, but no cigar: https://ecomodder.com/forum/member-f...10-images5.jpg |
