EcoModder.com
-   The Lounge (https://ecomodder.com/forum/lounge.html)
-   -   Have you ever replaced your water heater anode rod? (https://ecomodder.com/forum/showthread.php/have-you-ever-replaced-your-water-heater-anode-40776.html)
Xist 02-13-2023 02:28 PM
This video didn't sound interesting, but his videos have never disappointed me:
https://www.youtube.com/watch?v=Bm7L-2J52GU
Since the tank is made of steel which, I don’t know if you’ve heard, but doesn’t really like to be in prolonged contact with water, a sacrificial anode rod often made of aluminum or magnesium pokes down into the water to take the corrosion bullet for the rest of the tank and keep it from rusting.
The top of that rod lives buried underneath the foam insulation that's underneath this plug, and it can actually be replaced!
If you do that regularly, it can extend the life of your water heater significantly.
But almost nobody does that, including me.
Yay laziness!
But this isn’t a home improvement channel…
https://www.youtube.com/watch?v=2IUNIUZz4Os
Mom has complained many times about how quickly her water heaters die, could it be this [relatively] easy?
Home Depot has a 3-section anode for $35: 3/4 in. NPT X 42 in. 3-Section Aluminum Anode Rod
Lowe's has one for $40 and another for $50, so if you decide to do this, make sure you find out what kind of nipples your water heater has.
I certainly never thought I would use that sentence.
Imagine going to the store, seeing two types, calling home, and trying to cut to the chase: "Ma! What kind of..."
Both say "Can be installed with only 14-in clearance."
I would rather drill a hole in the ceiling and patch it afterward than replace my water heater more often than necessary, but I would totally pay a little extra for a three-section staff.
I wonder how this fellow would feel about one of those: https://www.youtube.com/watch?v=pUWoUM4Wttc
This is Amazon's choice: Magnesium Water Heater Anode Rod (44 inch Flexible) 3/4" NPT Thread for Rheem, Reliance, Richmond, Kenmore, GE by Kelaro
redpoint5 02-13-2023 03:06 PM
I've enjoyed all of the Technology Connections videos.
We can't say what causes mom's water heaters to go early without examining the cause of failure.
It could be scale buildup, or the sacrificial metal may have become depleted...
I thought about flushing my water heater recently, but then needed hot water right away and abandoned the idea. Figured if I were to flush it, then I've also got no excuse to not check the anode.
freebeard 02-13-2023 03:55 PM
Yes. Long ago, but it seems I did it twice for some reason. It's an eight gallon tank.
Xist 02-13-2023 10:55 PM
I have thought about running a couple hoses to the water heater and melting some ice while I dump sediments.
Yay laziness!
cRiPpLe_rOoStEr 02-13-2023 11:24 PM
Even though I have already stayed in hotels and houses with boilers like those, I never had to do the maintenance of a boiler. But anyway, I guess the tanks of those solar heating systems are supposed to also feature an anode rod.
oil pan 4 02-14-2023 09:28 AM
Yeah there's stuff I can think of that I would much rather spend $500 on than a new hot water heater.
A hot water heater is potentially a bomb and needs to be cared for properly.
I recommend a magnesium anode, ball valve drain and if it's electric only put a straight element in the bottom, change the magnesium anode every 2 to 3 years.
cRiPpLe_rOoStEr 02-14-2023 03:54 PM
I'd be quite concerned about magnesium, as it's supposed to explode when it's hot and in contact with water.
redpoint5 02-14-2023 04:02 PM
Maybe it's an alloy. Nearly everything is an alloy. Steel is an alloy, yet we call aluminum wheels "alloys". I'm sure "mag" wheels are an alloy as well.
cRiPpLe_rOoStEr 02-14-2023 04:07 PM
Sure it might be an alloy. The cost of a magnesium alloy might be quite high though. When it comes to aluminium, AFAIK it would always be used as an alloy, never pure, in contrast to cast-iron which for some applications may not have anything else added to it.
oil pan 4 02-14-2023 10:14 PM
They are high enough magnesium content to hiss when dipped in vinegar.
The main explosion danger is a steam.
redpoint5 02-14-2023 10:47 PM
I'm not afraid of hot water heater bombs mostly because I don't even know anybody, who knows anybody, who knows somebody that was harmed.
I did watch the Mythbusters episode though, and that was quite entertaining.
Perhaps the 1st stage of rockets should be steam powered hot water heaters?
alexshock 02-15-2023 05:51 AM
lol)) doing that once a year.
oil pan 4 02-15-2023 10:22 AM
Usually the case splits and all you get is a bunch of water damage.
redpoint5 02-15-2023 12:02 PM
Mine is located in the basement, in what I refer to as the boiler room where the furnace also lives. 2ft from the drain, so water damage would only be possible if it split on the side facing the drywall.
freebeard 02-15-2023 04:50 PM
Youtube insisted I should watch the video. Turns out I was wrong, I replaced the heating element, not the sacrificial anode.
My heater has no connections on the top, hot at the top of the side and cold at the bottom. And it doesn't have the fancy feature with only one heating element.
Since I long ago raised the bathroom vanity up 2" I could R&R the heater into an insulated box. I already have a manual on/off switch.
One disappointment was he used the term 'dip tube' when one of my new favorites is 'downcomer'.
cRiPpLe_rOoStEr 02-21-2023 02:54 AM
I spent 4 years without replacing the heating element of the shower at home, but I don't know how many times my father eventually did it while I wasted my time with my mother staying at her apartment :turtle:
Last time I had to replace the heater element, which was around 2 months ago, as I wasn't finding the appropriate heater for my shower, I had to compare the one for the 220-volt version to some random 127-volt until I found out one which seemed to have the same size.
Xist 02-21-2023 06:36 PM
What do you think about powered titanium anodes with 20-year warranties? Corro-Protec™ Powered Anode Rod for Water Heater, 20-Year Warranty, Eliminates Rotten Egg/Sulfur Smell within 24 hours, Stops Corrosion and Reduces Limescale, Electrical Anode Rod Made of Titanium
