HCH II Update recall for the IMA software Reflash
Just had the latest recall performed at the dealer on my 2006 Honda Civic Hybrid.
Seems to have improved acceleration a bit, will see what it does to the FE. Here's what the invoice says about the work done: Failed part: P/N 1K100-RMX-A07 Defect code: 5KC00 Symptom Code:R4200 Recall 10-034 1255B2 Update PGM FI Software. 0.3 A. Add for updating the IMA battery software. 0.3 B. Add for updating the A/T software. 0.3 C. Add for start clutch learning. 0.1 D. Add for CKP learning . 0.1 E. Add for PCM idle learning. 0.1 Thinking the numbers following the descriptions are for hours paid to the dealer for the recall. Just noticed the idiots at the dealership put 5-20W oil in the crankcase... the manual says it will work but 0-20W is prefered. I told them not to change the oil! I had just changed it to 0-20W Mobil 1. What a waste! You would think that Honda could use the correct oil. I will follow up with this after a couple of tankfulls. Had been getting 44 MPG. As a side note I found out that the top end of the HCH is 110 mph. Could do more if the road were longer. Sounded like there was a limiter kicking in though. Anyone else had the recall done? |
Just a quick update after 2 months driving with the flash.
Seems much better overall on acceleration and smoothness. I also noticed the the battery does not drop to no bars like it used to. Mileage has improved a bit, just finished a 600 mile trip with 47 MPG driving 65-85 MPH. I would say the recall flash fixed a few things. Anyone else had the flash done? |
