Heavier car = More MPG on the highway?
If you were to drive to a location and back the same way, wouldn't a heavier car = better fuel economy? Of course this is provided you don't brake or use engine braking. My thinking behind this is that you use more engine power on the uphills which boosts engine efficiency and reduces pumping losses etc. Because of the higher weight you also have a correspondingly higher kinetic energy at the top of the hill enabling you to coast in neutral further than with lower weight.
Is there some merit behind this way of thinking? Also, instead of the technique used by some to drop speed on the uphills and gain it on the downslope, wouldn't it make sense to use the throttle generously on the uphill and then also coast downhill of course? Yet again for the increased efficiency. |
if you can still stay off the brakes, some extra weight isn't much of a penalty. Though you will see a bit more rolling resistance. It depends very much on circumstance too.
http://www.rehab.research.va.gov/jou...warciakf02.jpg |
When you need more power to get up the hill you need more fuel. Recapture is never as good as not expending in the first place. And rolling resistance will be somewhat higher.
Engine size would really play a large part in this, too. An engine that is properly sized to the weight/mass of the vehicle it is propelling, rather than an engine which capable of much more maximum power than is warranted, will also help fuel efficiency.
Theoretically I guess it would be best with an engine at full throttle all the time? In practice though the problem would probably be that most cars have fuel enrichment at very high throttle levels. |
Maximum engine efficiency is found at as full a throttle as possible without triggering the fuel enrichment schemes. I generally figure the sweet spot load range to be 60-75% of maximum rated power.
One thing on keeping the load applied with the throttle; since I put a warm air intake on my truck I've noticed it won't hold as much load. It forces me to pay more attention when passing or climbing. |
Copyright ©2000 - 2021, vBulletin Solutions Inc.
